Feedback request: Hunter Tuned Injectors
Anyone used any of his decapped injectors? Im looking around for an e85 compatible injector that doesnt require too much modification to the rail or wiring. From what Ive seen on his youtube you may have to play with rail height but I havent really seen whats involved in the wiring of these.
re: Feedback request: Hunter Tuned Injectors
I tuned a car with them and didn't like them at all. They didn't wanna idle anything leaner then low 13's are the best regardless of what I did with injector dead times. I have a set of 210lb bosch injectors I found on eBay for $85 for a set of four that are e85 compatible and they work very well for as cheap as they are. They just need lower injector washers like id1000's do but diy tuning has those for $18 for a set. Other then that they fit stock fuel rails perfect and lower seals just fine. |
Thats what i was really concerned about is the tuning on them. Good to know |
Originally Posted by K7-1Ktrevor
(Post 51855951)
(Post 51855951)
They are at 120ms I believe. They ran good between 91ms and 120ms. |
Re: Feedback request: Hunter Tuned Injectors
I have a set on the way should be delivered today! I'll let you know how it goes
