Fan for turbo setup?
Guest
Posts: n/a
95 GSR with a drag kit and Fluidyne radiator.
My problem is that the stocks fans obviously don't fit with this fatty radiator.
I ordered a 9" fluidyne slim fan and it still wont fit between the radiator and manifold, I think it also is a little small??
Anyways am I able to use this fan on the other side of the radiator and would it still work the same?
Also, how I do I mount this thing? It came with some black ties and other miscellaneous stuff.
Thanks
Thanks
yes you can set it up o nthe other side of the radiator just make sure you ahve your polairty set right so its blowing correctly. Also you cna opt for the slim line fnas 12inch ones that would also works great .
yes, you can mount the fan on the front of the radiator. just reverse the polarity so the fan will push air through the radiator. the zipties go through the fins of the radiator.
have you looked into the T- FAL setups? they are pretty slim and great for most turbo applications. there is a set on ebay right now for like $115 + ship
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr »</TD></TR><TR><TD CLASS="quote">have you looked into the T- FAL setups? they are pretty slim and great for most turbo applications. there is a set on ebay right now for like $115 + ship</TD></TR></TABLE>
always finding deals on ebay
verbol axsassin
Apr 5, 2006 10:31 AM
