F20B PSI & CROME Q's
Old Oct 12, 2009 | 05:58 PM
f20bmt's Avatar
Default F20B PSI & CROME Q's
I have a question on how much boost I can safely tune for / get away with so here is the setup
93 hatch
F20b w stock internals
660 siemens deka injectors
chipped p28 on crome
turbo out of a stock Vr4 3000gt
also, my "boost tools" plugins dont work on the p28 base in crome but they do work in the p30 basemap, if I use the p30 basemap can I put that chip in my p28?
Old Oct 12, 2009 | 07:40 PM
mtber's Avatar
Default Re: F20B PSI & CROME Q's
There are too many variables for us to give you a "safe psi".
You could be running x octane with an x sized exhaust/down pipe, with an x sized intercooler & x style turbo manifold that flows like crap etc...
Concerning crome. Yes you can use p30 code on a p28 ecu.
Old Oct 12, 2009 | 09:02 PM
slow96lude's Avatar
nice reply....MY question is are you tuning this? Because you should know what PSI you can go to if you are. It really depends on the injectors and what you wideband says
Old Oct 12, 2009 | 09:03 PM
slow96lude's Avatar
I would post this on pgmfi.org forum. If you tune on crome and your not on that forum, your lost
Old Oct 13, 2009 | 05:31 PM
f20bmt's Avatar
sorry in order: 91, 2.5 staight out, 60x30x7.6cm, fabbed a ramhorn out of schd. 80 fittings. this is just a dd with a street tune. Im not shooting for huge numbers here just a low 300 would be nice. I guess my main question was that with the stock 11:1 pistons how far can I push this. is 300+ realistic or do I need to go back and redo the bottom end?
hard_boiled_EG
Nov 10, 2008 12:56 PM
ghostrider dc2
May 11, 2006 08:47 AM
n1_ek
Aug 15, 2004 09:20 PM
sampol999
Jan 21, 2004 07:11 AM
CWESTINAP1
Jan 23, 2003 05:41 AM
