Ever install a N2O gauge on A-pillar?
Old Oct 18, 2002 | 01:24 PM
816d16's Avatar
GDD's DJ EX-M0D
Community Builder
Community Influencer
Default Ever install a N2O gauge on A-pillar?
I've got my gauge, gauge pod, y, and braided line, and I'm ready to go. The only thing I'm worried about is f-ing up the pillar with the drill. Is it all pretty simple? I figured I would save myself $50 by doing it myself. Anything I need to worry about besides makeing sure the bottle is off ?
Old Oct 18, 2002 | 04:51 PM
Midwestrider's Avatar
Default Re: Ever install a N2O gauge on A-pillar? (816d16)
running the line in the pillar will be fun...
most ppl i know opted to mount that gauge eslewhere due to have to run the n2o line for gauge..
Old Oct 18, 2002 | 09:24 PM
Mista Bone's Avatar
D Tranny Guru
yeah like when the line at the gauge desides to leak and blows right in your face on the highway..........
Old Oct 18, 2002 | 09:51 PM
rjardy's Avatar
Default Re: Ever install a N2O gauge on A-pillar? (Mista Bone)
i dont think that i would run it in the cab, but i have never done it. Is it safe?
Rob
Old Oct 18, 2002 | 09:59 PM
speeddave's Avatar
Default Re: Ever install a N2O gauge on A-pillar? (rjardy)
the gauge set comes with a fitting that reduces pressures i believe, but i still busted a gut thinking of mista bones response... i wouldn't run it level with my face neither... maybe in the dash or glove compartment.
Old Oct 18, 2002 | 10:03 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Ever install a N2O gauge on A-pillar? (speeddave)
I was gonna mount mine in the glove box, but since my bottle is omunted behind drivers seat, I just look down at the bottle mounted gauge.
900 psi tonight, ran another 13.10 @ 103
Old Oct 18, 2002 | 10:04 PM
LordVtec's Avatar
I had my NOS press. gauge in the pillar and never had a problem.. its not hard to install and there should be no reason why you couldnt do it yourself.. just make sure you have teflon tape..
Old Oct 18, 2002 | 10:17 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Ever install a N2O gauge on A-pillar? (LordVtec)
yep, you should use teflon tape on AN/JIC fittings..........
NOT!!!!!!!
My used ZEX kit came with teflon tape on all the fittings.
[Modified by Mista Bone, 11:58 AM 10/19/2002]
Old Oct 19, 2002 | 06:41 AM
LordVtec's Avatar
NOT!!!!!!!
Must used ZEX kit came with teflon tape on all the fittings.
I never said you should use it on ALL the fittings, god forbid you get teflon clogged in a nitrous line... I didnt use the ZEX kit, i ran an NOS kit, and even though i didnt use teflon on all of the AN fittings i did use a little teflon on the back of the pressure guage fitting to stop a slow leak.. thats why i suggested it.. just my $0.02
[Modified by LordVtec, 10:45 AM 10/19/2002]
HONDA-2NR
Feb 24, 2004 04:31 PM
jacob
Feb 2, 2003 02:48 PM
B18EG6
Aug 7, 2002 12:31 PM
Dupes
Jul 11, 2002 03:23 PM
Defiant1999
Jan 5, 2002 07:10 AM
