EF hatch with b18 going boost ( radiator question )
Old May 16, 2013 | 07:11 AM
LuckyJDM's Avatar
Default EF hatch with b18 going boost ( radiator question )
What radiator should I get? Im thinking of ditching the oem radiator and going with either a half size radiator from an eg or maybe getting a aluminum one. Also should I use 2 slim fans or one? ive heard of people putting slimfans between the intercooler and radiator and then one where the fan is suppose to go? Im just worried about cooling for the motor while on boost. Dont want to overheat. Just throw at me some basic setups for cooling when going boost on a ef with ls swap
Old May 16, 2013 | 08:23 AM
Dark_Teg's Avatar
Default Re: EF hatch with b18 going boost ( radiator question )
The EG half radiator is too tall for an EF without leaning it which I didnt have room to do. The only radiator I found that would fit is the full race half radiator made for the EF chasis. It was expensive but did the trick. A turbo blanket, lots of heat wrap, and a good fan are a must.
Old May 16, 2013 | 10:05 AM
LuckyJDM's Avatar
^ thanks. I have heard that you need to cut the crossmember which I dont plan on doing so.. ill look in to some radiators that fit the ef/crx chassis
Old May 16, 2013 | 11:09 AM
ESP.net's Avatar
I think the best way is to notch the core support and use it as a mounting point. Drill 2 holes and use a piece of rubber tube around the studs of the radiator. I also use PWR EF half sized radiators spendy but worth it. It is made for the EF and is a couple inches shorter in height then the civic half size.
Old May 16, 2013 | 09:03 PM
stackedhouse's Avatar
Could always do the sirrocco radiator and tuck it
Old May 20, 2013 | 05:30 PM
LuckyJDM's Avatar
bump
Old May 20, 2013 | 06:56 PM
BLU CIVIC's Avatar
Track Advocate
i say keep the full size if you can, i did on both my cars. actually used a DA dual core radiator
Old May 20, 2013 | 07:15 PM
duf2570's Avatar
Love the blue vc !!!
EF9_RIDER37
Apr 3, 2010 08:57 PM
bigcivman09
Feb 23, 2009 06:09 PM
shosek03
Mar 25, 2008 11:33 AM
SimbaDogg
Jan 12, 2004 09:16 AM
