ebay RFL bov causing compressor surge
Old Sep 14, 2007 | 08:48 PM
boostmywankle's Avatar
Default ebay RFL bov causing compressor surge
Hey guys, just tuned my integra the other night at 5 pounds so far, and only at partial throttle im getting compressor surge. i don't see how to adjusted the bov because it doesn't have any settings. any idea? maybe try to find a softer spring? maybe its this ebay piece of ****?
bov is seeing vacuum from a vacuum manifold from the brake booster line.
any ideas would be highly appreciated
Old Sep 15, 2007 | 05:23 AM
Default Re: ebay RFL bov causing compressor surge (boostmywankle)
ha no one? someone has to have some insight
Old Sep 15, 2007 | 07:27 AM
boostedcivicsir's Avatar
Mr. Badwrench
take the cap off and take a washer or 2 out of the valve and go from there. if there are no washers, make sure the vac source is good, and if it is, thats the way it is.
Modified by boostedcivicsir at 11:49 AM 9/15/2007
Old Sep 15, 2007 | 08:47 AM
LShatchie's Avatar
Default Re: ebay RFL bov causing compressor surge (boostedcivicsir)
I have the same bov, I had to take the spring out and cut a couple coils off with my cut off wheel, works great now.
Old Sep 15, 2007 | 09:38 AM
Hondaruss's Avatar
Default Re: ebay RFL bov causing compressor surge (LShatchie)
Change your vac. source. I had the same problem with the vac block .. put it to the intake mani. .you'll be good to go!. I think what was happening was all the stuff i had on the block about 5 things all needed vac and i was only pulling 15hg of vac and it was not enough for the bov. Its best for them to have there on dedicated source any way
Old Sep 15, 2007 | 10:04 AM
Default Re: ebay RFL bov causing compressor surge (Hondaruss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">take the cap off and take a spring or 2 out of the valve and go from there. if there are no springs, make sure the vac source is good, and if it is, thats the way it is.</TD></TR></TABLE>
there is only 1 spring in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">I have the same bov, I had to take the spring out and cut a couple coils off with my cut off wheel, works great now. </TD></TR></TABLE>
so cutting a couple coils off of it, made it softer?
vac source is fine. im pulling like 22 inches. I had it teed at first off fpr and it was doing it, then i bought a vac manifold.
Old Sep 15, 2007 | 10:50 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmywankle &raquo;</TD></TR><TR><TD CLASS="quote">
me.
i know that.......he hee. my fingers disagreed with my hnead.
yes there is one spring, and yes cutting a coil or 2 will soften it up BUT it may open under boost.
Old Sep 15, 2007 | 12:32 PM
maybe ill give cutting a coil spring a try. Id hate to loose boost though. how are you suppose to soften them up if you have compressor surge without cutting a coil?
Old Sep 15, 2007 | 01:11 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmywankle &raquo;</TD></TR><TR><TD CLASS="quote">maybe ill give cutting a coil spring a try. Id hate to loose boost though. how are you suppose to soften them up if you have compressor surge without cutting a coil?</TD></TR></TABLE>
a softer spring.
thats the down fall. i have a reall stiff spring in my tial. it surges up to 14 psi, but if not it hangs open at idle he hee.
Old Sep 15, 2007 | 08:36 PM
lambertincorp's Avatar
run more boost the knockoffs cause compressor surge under 5-6 lbs i have 2 hks knockoffs and at 5-7 ;bs it would cause surge
Old Sep 15, 2007 | 11:53 PM
blinx9900's Avatar
Default Re: ebay RFL bov causing compressor surge (lambertincorp)
stupid question but how do you know its surge? is it a audible?
Old Sep 16, 2007 | 05:42 AM
Default Re: ebay RFL bov causing compressor surge (blinx9900)
i only get compressor surge at partial throttle and like 1-2 psi. at 5 psi there is no surge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">stupid question but how do you know its surge? is it a audible?</TD></TR></TABLE>
yes its audible...sounds like... cha cha cha cha
Old Sep 16, 2007 | 07:20 AM
Nichelson_Performance's Avatar
yup my BOV valve was a red RFL Type H or something, but yeah anyhow i cut the spring and shortened it up and it works fine, now and then i will get some surge but it's at very low boost levels and it only happens a certain way i let off the throttle. i started by cutting a half of a coil off mine cause u don't want it too short
Old Sep 16, 2007 | 10:26 AM
Default Re: ebay RFL bov causing compressor surge (Nichelson_Performance)
ok cool, ill give it a shot and let you guys know how it comes out. thanksss!
Old Sep 16, 2007 | 11:41 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostmywankle &raquo;</TD></TR><TR><TD CLASS="quote">yes its audible...sounds like... cha cha cha cha </TD></TR></TABLE>
dont some bovs go cha cha cha cha? or is that sound always surge?
Old Sep 16, 2007 | 01:14 PM
b18elvin's Avatar
hi i have a b18ls running 10psi of boost and sounds cha cha cha so many people told me is the blow off sound i have a ebay type rs.but i dont know if its compressure surge.
Old Sep 17, 2007 | 05:14 PM
Default Re: ebay RFL bov causing compressor surge (b18elvin)
compressor surge makes a fluttering sound like a bird flapping it wings i had it at first until i figured out that the spring needed cut
Old Sep 17, 2007 | 05:28 PM
Hondaruss's Avatar
This is a good example of compressor surge
http://videos.streetfire.net/v...f.htm
Old Sep 17, 2007 | 08:29 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaruss &raquo;</TD></TR><TR><TD CLASS="quote">This is a good example of compressor surge
http://videos.streetfire.net/v...f.htm</TD></TR></TABLE>
wow snaps thank you, i know a few people who need to loosen there bovs...
Old Sep 17, 2007 | 10:28 PM
jDMJeRk's Avatar
Buy real parts that work easy fix
Old Sep 18, 2007 | 04:42 PM
Default Re: ebay RFL bov causing compressor surge (jDMJeRk)
my ebay bov works fine now that i cut the spring and it's one of the loudest bov's i've heard on the boosted cars in my area.
Old Sep 18, 2007 | 07:28 PM
b18elvin's Avatar
my car sounds like the one in the video and everybody tell me then is the type rs blow off sounds like that.i tink i have a problem.
Old Sep 18, 2007 | 09:17 PM
blinx9900's Avatar
Default Re: (b18elvin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18elvin &raquo;</TD></TR><TR><TD CLASS="quote">my car sounds like the one in the video and everybody tell me then is the type rs blow off sounds like that.i tink i have a problem.</TD></TR></TABLE>
its just set too stiff, loosen it up some, my RS did the same when i set it stiff...
Old Sep 19, 2007 | 04:55 PM
b18elvin's Avatar
Default Re: (blinx9900)
its just set too stiff, loosen it up some, my RS did the same when i set it stiff...</TD></TR></TABLE>
i already loosen but he keep making the same sound,i want to know how the type rs blow off sounds,it sounds cha.cha.cha?
Old Sep 19, 2007 | 06:07 PM
blinx9900's Avatar
i already loosen but he keep making the same sound,i want to know how the type rs blow off sounds,it sounds cha.cha.cha? </TD></TR></TABLE>
when mine was stiff it was going cha cha cha, when i loosend it, then it just made 1 loud CHA! is yours all the way loose?
