e85+ ID 1000's
Old Feb 5, 2010 | 12:34 PM
boosted2.4's Avatar
Default e85+ ID 1000's
i searched but couldnt find what i was looking for. whats the most power someone has made on e85 using ID 1000's? also what was the base pressure, pump, and what size lines were used?
Old Feb 5, 2010 | 12:40 PM
HamiltonRex's Avatar
Default Re: e85+ ID 1000's
its very subjective.
perhaps you could shed a bit of light on what YOUR trying to do, then we can go from there and give you advice.
Old Feb 5, 2010 | 12:51 PM
boosted2.4's Avatar
i trying to make 650+ and was wondering if i would need to upgade my injectors. i will be running full blown setup with -10 feed -8 return aeromotive reg and my id 1000's. just not sure if it will be enough injector
Old Feb 5, 2010 | 01:50 PM
miller's Avatar
Put some 2000's in it and do it the right way.
Old Feb 5, 2010 | 02:05 PM
SPOOLINmatt's Avatar
im going to run 2000's and an aeromotive pro pump, maybe with a voltage booster as well. 1000's and a walbro could do anywhere from 500 - 600 from what ive read.
Old Feb 5, 2010 | 05:03 PM
tony1's Avatar
You won't get to 650whp on E85 on the 1000's, at 100psi fuel pressure. Your dual walbro setup won't make over about 75psi total pressure, which leaves you running closer to 40psi base pressure. At that fuel pressure, your only option is bigger injectors.
Old Feb 5, 2010 | 05:11 PM
boosted2.4's Avatar
thanks thats what i was wanting to know
Old Feb 5, 2010 | 06:54 PM
alpha's Avatar
If you want to stick with the ID1000's for the time being. Look into a dual Bosch 044 setup
centraldriver29
Jun 5, 2014 04:55 AM
sanman000719
Feb 1, 2012 12:30 PM
boostedb20z
Jul 19, 2011 06:43 AM
narfdanarf
Feb 1, 2009 04:37 AM
Familycarfromhell
Feb 11, 2003 06:01 AM
