Dyno today (56k ok)
started with a basline of 190 WHP
came out with 224.5 WHP and 218 lbs of torque!
give a 15% drivetrain loss that = 258 HP at the flywheel.
+35 WHP from just tuning
Boo-YAH!:D
tEh cIvIc KaN nEvAh l00$3!
solid blue = WHP
dotted blue = torque
ignore the red lines all together
JDM B18C
Greddy turbo + IC
RC550 cc injectors
skunk2 cam gears
EDIT: 8psi. it spiked to 10 psi
stock internals.
2 1/2" exhaust
HKS MBC
A big thanks to Wayne at http://www.garagefive.net
also my bud with a JRSC B16 went in the same time with 180 whp and left with 210 WHP
Modified by Turbo E 604 at 10:23 AM 6/29/2004
Modified by Turbo E 604 at 10:25 AM 6/29/2004
Modified by Turbo E 604 at 10:28 AM 6/29/2004
Boo-YAH!:D
solid blue = WHP
JDM B18C
Greddy turbo + IC
RC550 cc injectors
skunk2 cam gears
stock internals.
2 1/2" exhaust
HKS MBC
what fuel managment are you running ? the numbers are realy low , what was your a/f look like? here take a look at this dyno graph this is at 14.5 psi but it should give you and idea of where it should be http://www.boosted-hybrid.com/viewtopic.php?t=86
I am also suprised to see that low of numbers. I have a turbo gsr motor and will be disappointed if I dont see close to 300whp with it. Granted our parts might be a bit different, a gsr turbo on 10psi should have higher numbers. good luck
which greddy turbo?
what size exhaust?
what fuel mgmt?
which greddy turbo?
what size exhaust?
what fuel mgmt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 »</TD></TR><TR><TD CLASS="quote">
Nice power but you got some weeeird stuff going on up top. Why such a big drop-off? Looks like you're losing 30-40 hp for some reason.
I also got my car tuned by wayne, we just did street tuning though. I want to go back and get it dyno tuned.
How many hours on the dnyo? and what was the total cost (if you dont mind me asking)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">when I start reading it, I thought it was SOHC</TD></TR></TABLE>
no **** me too
i was like "oh **** , another D series turbo ninja!"
no **** me too
Your headgasket is blown? Dude, thats the problem why your not making as much power as you should be. Fix that and take it back in and get it retuned. Dont drive around on a blown HG unless you want to risk cracking the head or warping it.
Blaze
Blaze
It sorta looks like vtec didnt turn on. Are you sure vtec is working properly? That would account for the lack of topend power.
From right around where vtec should engage until redline you only gained 10-15whp. Thats just not right.
liam
liam
Did you check your timing? What fmu are you running? The last time I saw a torque curve fall that fast was when my timing on my dizzy was advanced too much, it never crossed my mind til my egt was hooked up and I was hitting about 1700* @wot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 »</TD></TR><TR><TD CLASS="quote">hmm i'll try backing up the spark.</TD></TR></TABLE>
Were you happy with Sean's tuning?
On Friday, me and a buddy had him tune our cars as well. I was really happy, but not as happy as my buddy. +62hp at the ground for a total of 230hp on a mini me Y7/8.
Kinetic rocks, hope you can fix your issues.
i backed up the spark and turned up the boost a tad. the car pulls like a freight train. and i had a bit of ping at the top end but now its mostly gone.
I have to say the torque is more of a handfull now
can someone critique my DATA readings?
my AF is all in the 12:1 range
