Dyno sheet, kind of disapointed.....
Well here is a pic of my dyno sheet.
I was hoping for 500whp but I guess I will settle for 426whp
Going back to the dyno to get 500whp.
b18c @ 21psi
plot 1 - 4th gear pull
plot 2 - nailed it 2nd gear
plot 3 - nailed it 2nd gear.
This was on a clayton dyno.
What you guys think???
Here is a larger view of the dyno sheet.
http://www.imagestation.com/mypictur...&id=4244923487
[Modified by ekb18c, 10:45 PM 11/22/2002]
[Modified by ekb18c, 12:02 AM 11/23/2002]
. Going back to the dyno to get 500whp.
b18c @ 21psi
Yes, all made in house. The exhaust and intake manifold.
The intake and exhaust manifold may look wierd because we are testing a certain air flow theory on each of them.
edit- yes, mustang TB
[Modified by ekb18c, 11:36 PM 11/22/2002]
If you dont mind, where is a Clayton dyno found in the area...
Fuel setup? DFI?...
Im sure you can squeeze the extra Hp out with some tunning...
Fuel setup? DFI?...
oh wow... colin, get in contact with me via phone or im when you get the chance to. im very proud of you, but you have failed daniel son. 500 is the goal !
could your guys make a similiar exhaust for my D? and how much would it cost,roughly?
ralphy at drt got 460 at 22 psi out of my tegra with a 60-1 and stock b16 head w/2001 itr cams, stock block too
but in any event, good numbers. Ralphy is a good tuner .
[Modified by ekb18c, 12:18 AM 11/23/2002]
I got full boost @ 6k, but we are still experimenting with the design of the intake and exhuast to make it hit bull boost faster..
Is the manifold meant to be equal length or what cylinder 1 and 2 seem to have shorter runner then 3 and 4, was is the idea behind it ...Looks wicked though and nice numbers whats the octane level of the gas your using..
