Dyno Results - Bensons 83mm/Eagle/CP LS/VTEC
I realize now what people mean when they say "Best exhaust for a Turbo is NO exhaust"
I have a tiny T3 .48 A/R Stage 2 turbine, with a 2.5" exhaust with an OEM cat. And the numbers show it. 291 WHP @ 7750 203 TRQ @ 7250 15 PSI Running 11.5:1 Air Fuel ratio The compressor is a nice T04E .60 A/R, 57 Trim wheel, so that helped make more power than the average .48 turbine wheel produces. The car still pulls like a freight train, and the power is usable on the street. Would've liked to break the magical 300, but hey, the motor has a whole 700 kilometers on it. Maybe once I'm done breaking it in, I will upgrade the whole exhaust and re-tune for 350 WHP. http://www.imagestation.com/picture/...4/f83d95d6.jpg Log Manifold, T3/T04E .48 Stage 2 turbine -.60 57 Trim Compressor Tial 35mm Wastegate Turbo XS RFL BOV 83mm Bensons LS Block (assembled by Earl) Eagle Rods CP 83mm 9:1 pistons B16 Head with GS-R cams MSD Ignition NGK BCPR7ES Walboro 255 in tank Hondata Stage 2B 720cc Injectors Centerforce DF clutch - 3 boosted years and holding! https://honda-tech.com/forums/images...s/emsmileo.gif http://www.imagestation.com/picture/...a/fc5152e2.jpg https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Dyno Results - Bensons 83mm/Eagle/CP LS/VTEC (Turboteggy)
that's awesome. https://honda-tech.com/forums/images/smilies/emthup.gif how much boost?
WOW, not bad at all. How many lbs were you boosting?
I like that hp curve. |
Re: Dyno Results - Bensons 83mm/Eagle/CP LS/VTEC (CharlesInTurbocharge)
15 PSI
I'll try to find the tune page - it's hard to read though http://www.imagestation.com/picture/...9/f83d95d8.jpg The green line is the A/F. The line it ~ follows is 11.62 Ranges from 11.4 (low) to 11.8 (high) The tune is VERY good and linear. https://honda-tech.com/forums/images/smilies/emthup.gif Chris Tapp @ TAPP AUTO - OTTAWA https://honda-tech.com/forums/images/smilies/emthup.gif |
Who made the exhaust manifold?
Re: Dyno Results - Bensons 83mm/Eagle/CP LS/VTEC (vtec69)
did you dyno w/out the exhaust?
Lookin good Todd. Did Chris do the tune? Nice graph for the street and it looks safe https://honda-tech.com/forums/images...es/emsmile.gif You can tell it is starting to run out of turbo but that is ok for now. That mani looks nice, also. https://honda-tech.com/forums/images/smilies/emthup.gif
I have a VERY similar set up :
same turbo as you 2.5 " exuast (what seems to be holding me back per tom @ payn) benson sleeved 83mm 9:1 cp/pauters b18c5 block hondata /750cc rc's walbro 255 etc I just got back from the dyno and the similarities to yours are astounding: @ 15psi :293.0 hp @ 8000 rpm / 211 ft-lbs @ 6250 and @ 19psi : 331.7 hp @8000 rpm/243.6 ft/lbs @ 6250 all on a mustang dyno as well. I just though the similarities were striking in both set ups and wish I had a way to post my graph http://images.honda-tech.com/set1//smile/emcrook.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Dyno Results - Bensons 83mm/Eagle/CP LS/VTEC (markaria)
Good numbers Todd drive the car this year do not get to aggressive on it and have probs
Re: Dyno Results - Bensons 83mm/Eagle/CP LS/VTEC (JDMCRX)
Don't worry, on a dynojet you are probally over 300whp, so there ya go! Also, upgrade that exhaust and I'm sure you'll reach 250whp. I had a stock caton my car, with stock B-pipe and RSR ex mag, and damn that shit was restrictive.
Re: Dyno Results - Bensons 83mm/Eagle/CP LS/VTEC (DRAGLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Who made the exhaust manifold?</TD></TR></TABLE>
My best friend. It's just a log mani, but I had it cerma-chromed. The wastegate dump is not as pretty, as it originally gonna be open dump, but I changed my mind halfway through, so it is kinda quick job, but it works. Thanks Earl, yeah, Chris did the tune. Said it was about as high as he's seen a .48 A/R Stage 2 turbine go as far as HP on Honda's. I'm guessing the 4-bolt outlet on the turbin, and unusually large compressor (for that turbine) made the diff. I think if we went to 8K, it would've hit 300 - it was definitely on track. Ah well, I wouldn't feel the extra 9 HP anyways...... Overall, I am pretty happy, we'll see if I get bored whether or not the exhaust/turbine will be upgraded.... https://honda-tech.com/forums/images/smilies/emwink.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Good numbers Todd!!
Another great job by Chris at Tapp Auto! |
Hey it looks like my dyno chart and number !!! great number !
