Dump Tube Temps
Old Aug 24, 2007 | 01:40 PM
LSEGHATCH's Avatar
Default Dump Tube Temps
What temperature would an open dump tube reach during normal daily driving with boost on occasion? I painted mine with standard spray paint without thinking and am curious if I'm going to be smelling that stuff burning off.
Old Aug 24, 2007 | 01:52 PM
SovXietday's Avatar
Default Re: Dump Tube Temps (LSEGHATCH)
If you do a lot of boosting, it's going to melt. If you don't, it'll probably be fine.
Old Aug 24, 2007 | 09:01 PM
90sedan's Avatar
Default Re: Dump Tube Temps (SovXietday)
Well the wastegate will only be open at full boost, so yes if you don't hit boost at all it will be fine. But, whats the point of having a boosted car then?
The paint will melt right off, give it a couple of days and it won't be there anymore. Just go out and buy some high-temp paint and re-coat it or just wrap it with header wrap
Old Aug 25, 2007 | 03:13 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Dump Tube Temps (90sedan)
i painted my dump tube w/ high heat temp paint and it still looks good
Old Aug 25, 2007 | 06:18 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
mine was painted with high temp paint to, came right off..... but i drive the **** out my cars
Old Aug 25, 2007 | 06:23 AM
HiProfile's Avatar
Default Re: (tannerLSt)
Take a propane torch to the paint, 4" away and hold it for 3 seconds, take away for 1 second, hold for 4 seconds, take away for 1 second, hold for 5-6 seconds...and you just gave it a 3-gear pull test. EGT's through the dump are ALWAYS going to be over 1200-1300F, and most ceramic walmart-style grill paint is barely rated for 1300F. Regular paint will fry much quicker.
Old Aug 26, 2007 | 03:52 PM
LSEGHATCH's Avatar
Default Re: (HiProfile)
I did the torch test but instead held the flame no the paint and did this for about 2 min so the entire pipe was warm. The paint didn't even smoke, so I'm just going to run it.
phoenix_iii
Paint and Body
10
Oct 10, 2023 11:58 PM
uberEFtuner
Feb 19, 2012 09:19 AM
redsolturbo
Paint and Body
Jan 25, 2009 08:40 AM
ontheline
Paint and Body
16
Mar 9, 2008 07:08 PM
1995silverinteg
Mar 26, 2004 01:38 PM
