Dumb turbo/hp question
Old Jan 27, 2003 | 06:49 PM
lazy bum shaughn's Avatar
Default Dumb turbo/hp question
Just wondering..
wouldnt a small turbo(example Garret T25) make the same power as a big turbo(lets say T4) at the same psi?
I know they are different sized turbos, but they're both pushing 8 lbs of boost(or however much psi) into your block.
Someone enlighten me, thanks.
Old Jan 27, 2003 | 06:59 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Dumb turbo/hp question (lazy bum shaughn)
the answer is no. the bigger turbo pushes more cfm than the smaller turbo. therefore it produces more hp. a t25 reaches is maximum efficiency at a lower boost level than a t4 also.
Old Jan 27, 2003 | 07:01 PM
spike's Avatar
Default Re: Dumb turbo/hp question (MotorMatrix.com)
i don't understand either really.. 8 psi is 8 psi.. from a small or large turbo... do larger turbos just push the 8 psi in faster??
Old Jan 27, 2003 | 07:05 PM
johnisenglish's Avatar
Default Re: Dumb turbo/hp question (spike)
Because smaller turbo's can't flow as much air, they end up heating up the 8psi they push more then larger turbo's at the same pressure, therefore making the air charge less dense, and therefore giving you less power
Old Jan 27, 2003 | 07:40 PM
I am a bad person
Default Re: Dumb turbo/hp question (johnisenglish)
the larger turbo flows more volume of air.
Old Jan 27, 2003 | 08:00 PM
queez's Avatar
k think of it as this analogy ... k pretend your pissing through a straw ..( the **** being the air forced into engine).. k now since your pushing 8psi it will come out fast but a little will only come out.. k now pretend your pissing through a 4"PVC PIPE. with the same 8psi. it stil comes out fast but at more volume so you get more air into the engine.
Old Jan 27, 2003 | 08:08 PM
BudaKai's Avatar
Default Re: Dumb turbo/hp question (queez)
Old Jan 27, 2003 | 09:54 PM
TurbothisLS's Avatar
hahahaha
i was gonna post an answer, but i think you've done it.[
CFM
Old Jan 27, 2003 | 10:02 PM
I am a bad person
nice analogy!! except I am high boost. i think i **** about 15+psi!!!
Old Jan 27, 2003 | 10:03 PM
DIRep972's Avatar
Smarter than you
i dont think someone could **** 8psi through a 4" pvc pipe. thats alot of pee
Old Jan 28, 2003 | 02:21 AM
MiraiZ's Avatar
Default Re: Dumb turbo/hp question (DIRep)
here we go again...can someone show this guy the water on the pinwheel again!
Old Jan 28, 2003 | 02:38 AM
LJR-LUDE01's Avatar
good way to explain it
[Modified by LJR-LUDE01, 6:39 AM 1/28/2003]
Old Jan 28, 2003 | 04:42 AM
ricodemus's Avatar
Default Re: Dumb turbo/hp question (LJR-LUDE01)
but with that analogy, it seems like you are focusing on the means the **** is traveling (straw or pipe), which would be the size of the charge pipes in a turbo system.
https://honda-tech.com/zerothread?id=305405
[Modified by ricodemus, 8:50 AM 1/28/2003]
Old Jan 28, 2003 | 05:27 AM
falcongsr's Avatar
What is this crap?
Default Re: Dumb turbo/hp question (ricodemus)
someone just post the links to all the previous threads on this?
Westrock2000
Nov 27, 2006 03:02 PM
sm00thk0zz
Jul 20, 2006 06:47 AM
JalopySiR
Sep 15, 2005 03:12 PM
