DRAG TURBO SPECS
Old Aug 28, 2001 | 07:54 PM
SiRkid's Avatar
Default DRAG TURBO SPECS
Anyone knwo them?????
trim, a/r etc?
thanks.
Old Aug 28, 2001 | 07:58 PM
Rob03Pro5's Avatar
Default Re: DRAG TURBO SPECS (SiRkid)
I believe the DRAG turbos are T04E/T3.
Compressor
T04E 46 Trim
Exhaust
T3 .63 AR Stage 2 turbine
Hope this helps.
Old Aug 29, 2001 | 05:48 AM
Seraph0's Avatar
Default Re: DRAG TURBO SPECS (Rob92SC)
That is pretty much exactly what I got on my GSR kit.
(ONly thing not TOTALLY sure of is the turbine trim... didn't know enough back then to tell... It's been two years since I turboed!)
Old Aug 29, 2001 | 06:48 AM
ArizonaTurbo's Avatar
Compressor
T04E 46 Trim
Exhaust
This is correct!
Hope this helps.
Old Aug 29, 2001 | 07:00 AM
SiRkid's Avatar
Default Re: DRAG TURBO SPECS (APEXSER)
thanks
wont this not be good enough!?
46 is kinda small.
[Modified by SiRkid, 4:01 PM 8/29/2001]
Old Aug 29, 2001 | 09:19 AM
Seraph0's Avatar
the .46 can push 400whp from what I have seen.
Old Aug 29, 2001 | 09:32 AM
SiRkid's Avatar
Default Re: DRAG TURBO SPECS (MarkC)
it wont die out on the top end ????
Old Aug 29, 2001 | 09:54 AM
QuickHonda's Avatar
You guys actually mean they have the exact same specs on all their kits. Can one set of turbo specs really work good enough on all their kits to justify not doing the research to find the "perfect" combination for each motor. Just seems like a turbo for a 100hp d series motor would be different than a nice 200hp b or h motor.
second question-are the specs the same for the gen2 kits and the gen3 kits?
Old Aug 29, 2001 | 09:55 AM
Rob03Pro5's Avatar
SirKid,
The T04E will only die out on you top end if you have a small exhaust housing. Generally, cars with high rev limits dont like small exhaust housings. Example: GSR w/ T04E/T3 .63 will produce higher hp numbers in higher rpm band than a T04E/T3 .48.
Old Aug 29, 2001 | 11:47 AM
chri5's Avatar
Default Re: DRAG TURBO SPECS (QuickHonda)
I believe that the b16 and the h22 kits have to4b compressors, not the to4e. And as for the b18b and the dseries ??? Hell if I know.
Old Aug 29, 2001 | 12:18 PM
Ben Huynh's Avatar
Default Re: DRAG TURBO SPECS (Strng1dah)
B18: T04E/T3
B16: T04B/T3
H22: T04B/T3
H23: T04B/T3
F22: T04B/T3
F23: T04B/T3
D16: T04B/T3
D15: T04B/T3
Different B turbos are supplied for different engines.
Old Aug 29, 2001 | 12:23 PM
VaporTrail's Avatar
New User
Default Re: DRAG TURBO SPECS (ben@importparts.com)
yes, but what people really want to know are the specs, especially trim and a/r
Old Aug 29, 2001 | 12:36 PM
Ben Huynh's Avatar
Default Re: DRAG TURBO SPECS (VaporTrail)
B18 E 54 STAGE 3 .63
B16 SUPER V-72 .63
H22 SUPER V STAGE 3 .63
H23 SUPER V STAGE 3 .63
F22 SUPER V STAGE 3 .63
F23 SUPER V STAGE 3 .63
D16 SUPER V-72 .63
D15 SUPER V-72 .63
Technically, I'm not supposed to release these specs but what the hell.
[Modified by ben@importparts.com, 1:37 PM 8/29/2001]
Old Aug 29, 2001 | 01:21 PM
SiRkid's Avatar
thanks ben!
you are the man!!!!!!
Old Aug 29, 2001 | 02:33 PM
Seraph0's Avatar
to Ben.
To SiKid.. Rob was right. .46 wont "die out" until 400whp. If you look in Sport Compact car.... that Monster Miata in there. He has a .46. I have seen it with MY OWN EYES. IT is the exhaust housing being to restrictive that will cut into top-end. Rob hit it right on the
Old Aug 29, 2001 | 02:55 PM
Rob03Pro5's Avatar
Thank you, MarkC!
Old Aug 29, 2001 | 03:03 PM
dbman96's Avatar
New User
OK now here's a fun one - I'm looking to swap the hot side of my turbo - right now it's a T3-0.48 Stage 1
Easy solution is to just get a 0.63 housing and go from there...
How much better would it be to go stage 3 and replace the whole hot side? Enough to justify the additional cost and effort?
Old Aug 29, 2001 | 03:07 PM
Rob03Pro5's Avatar
Default Re: DRAG TURBO SPECS (dbman96)
You basically talking about a turbo rebuild there. The whole assembly will have to be taken apart.. then once that is apart, replacing all seals is a must. I'd say stick with the Stage 1 and get the.63 housing. Yes, there are a few trade offs: PROs ~ You will lag less than Stage 3. CONs ~ You might not produce as much top end hp as a Stage 3.. but we're not talking massive amounts of HP.
Old Aug 29, 2001 | 03:28 PM
dbman96's Avatar
New User
Thanks rob, I think that's what I'm going to do... I can do the housing for $125 and I know it's an easy job once I drop the turbo off, and I've been meaning to get my manifold off for some porting and cleanup work anyway (and to see if I can fix some cracks!) so that sounds like the solution for me.
Old Aug 29, 2001 | 03:30 PM
Rob03Pro5's Avatar
Great idea on porting the manifold. Just make sure the manifold side openings are just a little larger than the gasket's opening. This will help fight reversion.
Old Aug 29, 2001 | 03:54 PM
SiRkid's Avatar
You guys are all great!!!!!
Old Aug 29, 2001 | 05:14 PM
dbman96's Avatar
New User
It's particularly a good idea if you look at my manifold - I bought it used and kept it for lack of funds; it looks like it was welded by a 3 year old on acid. The interior is all distorted with sharp edges sticking out for no apparent reason... been meaning to grind it out but just haven't had time since the turbo install... and have a wedding coming up so I haven't had a lot of free weekends to drop my exhaust hardware off. Somehow fiancee doesn't think car is a "priority" with a wedding in 2 1/2 weeks... crazy women.
Old Aug 29, 2001 | 06:06 PM
Seraph0's Avatar
I would keep the Stage1 too. Ask Arturbo what it cost to get a new shaft for his stage3. The turbine shaft is basically the whole expense of the turbo. IT is about $250 for the turbine shaft alone. The center housing is like a whole $75.
So if you wanted to change to a Stage3 it would probably cost you around $400.
UGh.... DITCH that .48 on the Stage1 (stock) tho. Yuck.
Old Aug 29, 2001 | 07:51 PM
Reid's Avatar
Global Moderator
ok... my exhaust housing reads .63 and the compressor says a/r .60. What does this all mean? How does my turbo measure up to a turbo that comes in a B18 DRAG kit?
Thanks,
Reid
Old Aug 29, 2001 | 08:14 PM
Rob03Pro5's Avatar
Default Re: DRAG TURBO SPECS (Reid)
You must have a straight T3.. with a 60 trim compressor and a .63 exhaust housing. This turbo is much smaller than the T04E 54/ T3 that the DRAG comes with. But it spools much faster probably. when do you get boost?
