does cometic make a turbo headgasket?
Old Feb 5, 2006 | 11:54 AM
the.hamburglar's Avatar
Default does cometic make a turbo headgasket?
could only find one part number on their webpage. just wondering if they make a few sytles for a 95 b18b?
Old Feb 5, 2006 | 01:15 PM
Default Re: does cometic make a turbo headgasket? (the.hamburglar)
ttt
Old Feb 5, 2006 | 01:17 PM
SOHCD16y8's Avatar
As far ar I know there is just heavy duty and extreme duty. Ive used both, never had problems with either.
Old Feb 5, 2006 | 01:22 PM
earl's Avatar
What exactly is your definition of a "turbo" head gasket. They have a full line of multi layer steel sandwich gaskets that work great on turbo applications. Many thickness and bore sizes available for all B series engines.
Old Feb 5, 2006 | 02:20 PM
Default Re: does cometic make a turbo headgasket? (earl)
i guess i ment to say something that will be stronger. how about this one on page 27 for a b18b?
http://www.cometic.com/catalogs/AutoCat04.pdf
Old Feb 5, 2006 | 07:03 PM
LilCivic04's Avatar
i prefer to use oem gasket or golden eagle, b/c i used cometic and blew that hg in like 2500 miles. its either a hit or miss on those head gaskets
Old Feb 5, 2006 | 07:13 PM
k24em2's Avatar
Default Re: does cometic make a turbo headgasket? (LilCivic04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote">i prefer to use oem gasket or golden eagle, b/c i used cometic and blew that hg in like 2500 miles. its either a hit or miss on those head gaskets</TD></TR></TABLE>
Not really. 99% of the time its installer error.
Old Feb 5, 2006 | 07:30 PM
earl's Avatar
Default Re: does cometic make a turbo headgasket? (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">
Not really. 99% of the time its installer error.</TD></TR></TABLE>or the parts that are being sealed together
Old Feb 5, 2006 | 08:40 PM
how can you have user error in installing a headgasekt?
oh i get it people to check to see if the block and head are true?
Old Feb 5, 2006 | 09:49 PM
k24em2's Avatar
Block/Head flatness, surface finish, etc. I think Cometic specifies 50RA or finer finish for their MLS gaskets.
Improperly torquing the head doesn't help either.
Old Feb 5, 2006 | 11:05 PM
93LSivic's Avatar
Cometic has the HP gaskets. Known as High Pressure. They are still an MLS gasket but they have a thicker ring that surrounds the bores in order to provide additional sealing for boosted/n2o applications. We usually try to stock them in various sizes and thickness's, if you cant find one then its usually a 2-3 week wait from Cometic for them to make one.
Old Feb 6, 2006 | 07:32 AM
LilCivic04's Avatar
Default Re: does cometic make a turbo headgasket? (93LSivic)
how the hell would it be installer error? i built a spare motor on the side to build and did everything correctly. i torque them down correctly step by step in order.
Old Feb 6, 2006 | 01:18 PM
SOHCD16y8's Avatar
As mentioned before, were the surface flat and freshly decked?
Old Feb 6, 2006 | 02:09 PM
Default Re: (SOHCD16y8)
the regular headgasket will still be ok right? planning on doing 10psi
Old Feb 6, 2006 | 04:24 PM
SOHCD16y8's Avatar
yeah it will be fine, you could use an OEM and be fine also.
SOHCD16y8's Avatar
Im assuming you will be using ARP headstuds also
Old Feb 6, 2006 | 04:32 PM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote">how the hell would it be installer error? i built a spare motor on the side to build and did everything correctly. i torque them down correctly step by step in order.</TD></TR></TABLE>
How could I verify that? ( no offense ) .
Did you check for surface irregularites?
Old Feb 6, 2006 | 05:31 PM
Default Re: does cometic make a turbo headgasket? (MidShipCivic)
yes i have arp headstuds
Old Feb 6, 2006 | 08:02 PM
LilCivic04's Avatar
was the surfaced straight? damn dude you act like i am dumb. i had the block resurfaced when i got it sleeved and had my head resurface when i had my port job done.
Old Feb 6, 2006 | 08:08 PM
LilCivic04's Avatar
just make your life simple and go with oem
Jokerchris
Mar 21, 2015 01:42 PM
cilvercivic
11
Apr 16, 2010 01:10 PM
bukbukintegra
May 27, 2005 12:15 AM
Lmgrcivic
Feb 6, 2005 04:55 PM
donkiman
Jan 24, 2005 08:10 PM
