does block need to be notched for rod clearence?
Old May 23, 2004 | 10:07 PM
turbosi03's Avatar
Default does block need to be notched for rod clearence?
I have a b16a2 block being sleeved right now... plan to use an LS crank with Crower rods (for LS stroke) in the b16 block... I'm trying to find out for sure if the block needs to be notched for the rods to clear. I pulled the LS rods/crank out of another b16 motor that had the notches, so that makes me think it needs to be done.
anyone know for sure?
Thanks!
Old May 24, 2004 | 07:31 AM
turbosi03's Avatar
Default Re: does block need to be notched for rod clearence? (turbosi03)
bump for odd hours...
Old May 24, 2004 | 07:39 AM
RyanEJ8's Avatar
I doubt it. I've only ever heard of block notching in the D series, since the smaller bore makes less room for thick rod. If you do need to notch it, there are some excellent directions on doing it here...
http://www.theoldone.com/artic..._tips/
Old May 24, 2004 | 09:01 AM
turbosi03's Avatar
Default Re: does block need to be notched for rod clearence? (RyanCivic2000)
yeah thats all I found, but I havent seen many people with stoker kits either... I guess since stroker kits are usually in NA motors maybe I should repost there...?
thanks for that link, I would be afraid to do that myself since the block will come back with a fresh set of Benson sleeves... but what the hell if it doesnt fit I'll just grind it.
Ronnie Cason
Engine Machining & Assembly
May 15, 2016 12:12 AM
slowassBubble
Jul 1, 2011 04:57 PM
Yeah Daybid
Mar 12, 2010 03:34 PM
Topdawgg
Jan 5, 2006 06:32 PM
turbosi03
May 25, 2004 02:02 PM
