Does batter voltage affect performance?
Old Aug 16, 2002 | 12:43 PM
Trac226's Avatar
Default Does battery voltage affect performance?
Recently I had an electrical load dectector problem that kept draining my new battery, but with h-t's help I fixed that and now my car starts up just fine. But when driving, my car bogs big time above 3k rpm. I'm wondering if it could be the battery.
[Modified by Trac226, 9:49 PM 8/16/2002]
Old Aug 16, 2002 | 04:51 PM
98lude's Avatar
Default Re: Does battery voltage affect performance? (Trac226)
deserves a bump cos I would like to know too.....how does battery voltage affect your sparks since my voltage is like 12.5V when idling and 13.9 while driving. Can't imagine what it is while cranking
Old Aug 16, 2002 | 06:16 PM
ekb18c's Avatar
A weak battery shouldn't make it bog that bad. If I remember correctly the voltage should be min. 14.0 at idle.
Old Aug 16, 2002 | 06:35 PM
Trac226's Avatar
Default Re: Does battery voltage affect performance? (ekb18c)
Doh, mine was around high 11- 12v when i got it tested today
Old Aug 16, 2002 | 09:26 PM
filetofit
Guest
Posts: n/a
I doubt it's your battery, your alternator supplies power to the car when it's running. I suupose it could be a bad voltage regulater in the alternator, but I'd check the distributor cap and rotor, plugs etc. before I went and replaced an alternator.
Old Aug 16, 2002 | 11:56 PM
98lude's Avatar
so the voltage should be min of 14 at idle? does that mean that a) battery is bad
b) alternator is bad?
thanx
Old Aug 17, 2002 | 01:02 PM
Charlie Moua's Avatar
Default Re: Does battery voltage affect performance? (98lude)
ttt
Old Aug 17, 2002 | 04:27 PM
Trac226's Avatar
Default Re: Does battery voltage affect performance? (Charlie)
The voltage option on my apex-i timer says its 12.4 now at idle. But something still feels wrong with my car, hopefully I'll get more clues when I dyno next week.
Old Aug 21, 2002 | 05:49 AM
ekb18c's Avatar
Default Re: Does battery voltage affect performance? (kennya70)
all you guys show signs of a bad alternator, It's going bad. I recently noticed that my voltage is at 13.9 at idle. It's suppose to be at 14.2-14.4, therefore my car once in a while just dies.
Old Aug 21, 2002 | 06:24 AM
VTC_CiViC's Avatar
Interesting that you guys mention this. A long time ago, I had a problem with my lights randomly dimming on their own as I'd drive. I could actually see the headlights on the ground dim and brighten over and over randomly. I took it to the dealer and they replaced my Alternator under warranty. Well fast fwd to today (3 years later) and it seems like I'm having the same problem. On the thottle, my GReddy timer shows about 12v, as soon as I let go of the gas, my lights slightly brighten and I get a jump to 13v+ on the timer before it drops againto like 11-12v at idle.. any idea what could be causing this? Alternator or something else? My tuner mentioned something inside the cabin, just above the ECU which is supposed to regulate voltage than according to him tends to go bad on Honda's but I can't recall exactly what it was..
Old Aug 21, 2002 | 06:44 AM
CovertFI's Avatar
thanx
that cant be right at all. i have a gps receiver that monitors voltage and it stays above 12v on the road it is about 13v. anything below 12v is bad
Old Aug 21, 2002 | 01:37 PM
98lude's Avatar
You sure? for one, I have the AEM pulleys on my car, so I am wondering if that will cause my battery to have a lower voltage at idle. When I step on the throttle, the voltage will go to at least 13.8, if not more.
Old Aug 21, 2002 | 11:28 PM
Trac226's Avatar
My battery voltage meter reads around normal now in the 14's. I think I was just bogging from the new intercooler and slightly soft BOV. I added a boost controller and tightened the BOV, and it seems to help spool up quicker.
[Modified by Trac226, 8:29 AM 8/22/2002]
vtecnique69
Nov 7, 2014 08:20 AM
vtecnique69
Honda Civic (2006 - 2015)
Nov 7, 2014 08:18 AM
Tommy_Gunns
Sep 11, 2009 12:10 AM
Si_chRis
Oct 21, 2006 03:36 PM
SkyeC
Jan 12, 2004 01:42 PM
