do i need to re-tourge headstuds again?
when i first installed my arp's, i gradually trq'd them from 15-35-50 then drove the car and then re-did them again to 81. do i need to re-trq them again before i hit really high #'s? the car is making 350whp right now, but im gunna re-tune soon for 450-550whp do i need to do this again or should i be fine? |
Re: do i need to re-tourge headstuds again? (fafsa)
it doesnt hurt to check it out
You should be fine if you used the ARP lube on them. I'm assuming a MLS head gasket.
Re: (rmcdaniels)
thanks for the responces, is it common for people to re-trq them again? |
I have heard of it, but not so much with a MLS gasket. Back in the old days when head gaskets were relatively compressible it was common practice to run it and re-torque, but it shouldn't be necessary with ARP studs and a MLS gasket.
Re: (rmcdaniels)
after about 10 heat cycles, mine were off by about 5 ft/lbs.
i would check them, it only takes a min... platinum. |
Re: (platinum00)
You only need to retorque them if its tuned by Stoney at velocity. I mean he can do it all from tuning and blowing motors all in one package. For a good price too.
Re: (Honda_4_Life)
haha, WTF
platinum |
Re: (Honda_4_Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_4_Life »</TD></TR><TR><TD CLASS="quote">You only need to retorque them if its tuned by Stoney at velocity. I mean he can do it all from tuning and blowing motors all in one package. For a good price too.</TD></TR></TABLE> HAHA<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">after about 10 heat cycles, mine were off by about 5 ft/lbs. i would check them, it only takes a min... platinum.</TD></TR></TABLE> thanks for the info |
Lucky D-Series bastards don't have to remove the cams...I've got a retorque coming up and am not looking forward to yanking everything out of the head again. https://honda-tech.com/forums/images/smilies/emsad.gif
Re: (DaX)
Re: (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">another reason to stay with the D. https://honda-tech.com/forums/images/smilies/emthup.gif
</TD></TR></TABLE> Yup https://honda-tech.com/forums/images/smilies/emthup.gif lol |
Re: (yellowturbo)
up
Re: do i need to re-tourge headstuds again? (b18bturbo)
it does NOT take a minute to retorque them. LOL.
it's a pain to take everything apart. |
Re: do i need to re-tourge headstuds again? (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">it does NOT take a minute to retorque them. LOL.
it's a pain to take everything apart.</TD></TR></TABLE> sure it does when your running a SOHC.. https://honda-tech.com/forums/images...s/emsmilep.gif you dont gotta take anything apart, just remove the valve cover.. platinum |
Re: do i need to re-tourge headstuds again? (platinum00)
up
bump
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Lucky D-Series bastards don't have to remove the cams...I've got a retorque coming up and am not looking forward to yanking everything out of the head again. https://honda-tech.com/forums/images/smilies/emsad.gif</TD></TR></TABLE>
I was gonna say. . . WTF? If you can pull the cams in a minute. . your goood! But then I saw we were reffering to a puny D series. . . https://honda-tech.com/forums/images...s/emsmilep.gif jk |
Re: (fafsa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fafsa »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Dude. . You already got the answer. . .check emm! |
