do i need a fuel rail???
Old Feb 11, 2004 | 07:05 AM
ATS*Mark's Avatar
OG triple OG
Default do i need a fuel rail???
i only plan on making around 200whp on my d series turbo . and i know most people buy the rails for bling , but do i NEED a rail ? i have rc 440's and a walbro 255 pump
Old Feb 11, 2004 | 07:17 AM
underpressure02's Avatar
Default Re: do i need a fuel rail??? (Hella_JDM)
I would say no. I believe you stock fuel system is good up to 450-500 HP. Atleast that is what Boosted Hybrid use to say. I think the fuel rail is mainly for bling like you said.
Old Feb 11, 2004 | 07:19 AM
ATS*Mark's Avatar
OG triple OG
Default Re: do i need a fuel rail??? (underpressure02)
thats what i figured , that if i have a good fuel pump and good injectors that i wont need a rail
Tinker219's Avatar
ya, unless you want to run -8 or -10 an lines, fuel rails are for show queens
Old Feb 11, 2004 | 07:31 AM
quikB18B's Avatar
Stock is fine, unless you want it for looks....
Old Feb 11, 2004 | 07:36 AM
ATS*Mark's Avatar
OG triple OG
Default Re: do i need a fuel rail??? (quikB18B)
cool thanks
Old Feb 11, 2004 | 10:10 AM
dfoxengr's Avatar
Default Re: do i need a fuel rail??? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">ya, unless you want to run -8 or -10 an lines, fuel rails are for show queens </TD></TR></TABLE>
you can bore your stock one larger. hence no new lines
Old Feb 11, 2004 | 10:46 AM
USDM 4G VTEC's Avatar
Default Re: do i need a fuel rail??? (hybridvteceg)
or u can be like me
just got a Edelbrok Pro Fuel Lite 5/8" inside diameter fuel rail for free for doing a MPFI to my buddy
and yes once u floor ur car , it will make a difference if u are making more than 175whp i say
Old Feb 11, 2004 | 11:25 AM
Muckman's Avatar
Moderator in Chief
I agree with these guys. The stock rail has enough capacity to supply a ton of power. The only reasons I see for upgrading (aside from bling) is the need for a fuel gauge port as some cars have NO way to easily tap the fuel system (5th gen prelude for example). You can also flip the fuel input port to the other side if you wanted to rework your fuel lines for whatever reason.
Old Feb 11, 2004 | 11:56 AM
accordfreak's Avatar
Default Re: do i need a fuel rail??? (Muckman)
i got an aftermarket rail to make it easier to install the paxton fpr
Old Feb 11, 2004 | 01:00 PM
blackeg's Avatar
Default Re: do i need a fuel rail??? (accordfreak)
its not necessary for your application, unless you want the bling
Old Feb 11, 2004 | 06:44 PM
mskibbz-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I agree with these guys. The stock rail has enough capacity to supply a ton of power. The only reasons I see for upgrading (aside from bling) is the need for a fuel gauge port as some cars have NO way to easily tap the fuel system (5th gen prelude for example). You can also flip the fuel input port to the other side if you wanted to rework your fuel lines for whatever reason.</TD></TR></TABLE>
Yup, I got one because it was easy to add accessories too.. I plan on installing an Aeromotive FPR & SS lines soon and its going to make it a necessity anyways.
Quickridez_3
Dec 22, 2022 11:18 AM
TurboB16A300Hpteg
Feb 25, 2008 06:08 PM
xtremecoupe
Dec 9, 2005 06:06 PM
irocdaparty85
Jun 3, 2005 08:15 PM
Type-ARR
Feb 28, 2002 01:41 AM
