Re: Discussion Topic: Let's talk Intercoolers!!
1 Attachment(s)
Originally Posted by TheShodan
(Post 49681161)
That's fine. I'm not worried about the numeric data charts really. Cerakote is not a very common material in most powder coating facilities. Cerakote was one of the ones we did for some rifles and other aluminum materials. We didn't see an improvement in the efficiency of heat exchange rate of the intercooler (I have to admit we only tested the temperature of the air before exchange and at the throttle body.)
Now, Tepid1 may have had a much better way to apply the measurements of the temperature changes at the site of the intercooler, but Cerakote's main purpose is for aluminum protection from scratches or damage, not for additional heat exchange efficiency. Cerakote is in the same boat of Duracoat, and Moly Resin when it comes to protection of aluminum, but doesn't really assist in heat-exchange efficiency. However, many firearms sources agree that for the best protection, HA-III (hard anodized type 3) is the best process to use. The HA-III electro-chemical process "transforms" the external surfaces of the Aluminum, resulting in a new surface that is very tough, very resistant to scratches, salt, and many other chemicals. It is "the" best process for Al, and companies such as SureFire and others that do military gear always use this process to protect the Aluminum pieces. But because anodizing comes in better colors and is applied differently than powdercoat, it satisfies most people's needs for aluminum protection and a nicer aesthetic look. If you want better exchange efficiency, than really, the best thing to do to an intercooler is.... nothing. Leave it alone. Guys. Remember, the purpose of the intercooler is to lower engine cylinder pressure temperatures by an exchange of heated air created by the compression of air (by increasing the kinectic energy of the air molecules turbocharger to cooler air that enters into the combustion chamber) for cooler air. Intercoolers do not "dissipate" heat, even by definition. To dissipate is "to disperse or scatter" something, even as anomalous as heat created by the turbocharger's compressor. An intercooler's purpose is not to disperse or scatter anything, but to exchange its air, using forced airflow from the outside through its fins to lower the temperature of the compressed air so that the air entering into the engine's air intake system does not increase engine cylinder temperatures that are already higher from the increased engine compression and combustion when turbocharging. There is more than one way to achieve lower IAT's. That's really the desired result. |
Tepid, I understand what you are saying but then again I know what kind of intercooler setup you run and how you have it configured, along with the coatings you use in various places on different components ;)
ps I'll be pm'ing you later today. I finally got the rough calculations done for my ubermotor and wanted to get your advice about my rod length and compression height along with some questions about your experience with aluminum rods since I'm going to be running a set. also a few questions on monitoring various engine parameters <3 |
Originally Posted by tepid1
(Post 49681568)
EDIT: I'm retracting my detailed response. I don't use an IC the same way everyone else does therefore it won't make sense to the masses. I'm done.
There is more than one way to achieve lower IAT's. That's really the desired result. I was relly hoping for you to respond... |
Originally Posted by turbohatch96y7
(Post 49681987)
Fuuuuuck
Yea to a degree the large surface area of the typical fmic acts as a heatsink. the size along with aluminums ability to transfer heat means that it will help to lower charge air temps in addition to the air flowing through the core.
After I go for a drive, the cold side of my intercooler feels cooler than ambient temp.
I'm not sure why this is, there's nothing special about it just plain old aluminum. It must have something to do with the thermal conductivity of aluminum, so I'm guessing if a coating can increase this conductivity it could also increase this "chilling" effect? |
I'm sure wind chill has nothing to do with ambient temp
:thud: |
Wind chill only affects perceived temperatures. Denser materials feel cooler/hotter because theres more molecules exciting your nerves.
65 degree air temp feels nice, 65 degree water temp is bone chilling. Same goes for the opposite direction Windchill occurs because wind causes more air molecules to hit your skin. |
(Post 49685905)
:thud: Wind chill really only changes the rate and which something will cool, but it will NEVER go below said ambient temp. A solid or liquid always "feels" cooler than it actually is. Like m4xwellmurd3r said, it's all about perception. |
No, I was joking.
Originally Posted by Str8 outta Cliff
(Post 49685748)
I'm not sure why this is, there's nothing special about it just plain old aluminum. It must have something to do with the thermal conductivity of aluminum, so I'm guessing if a coating can increase this conductivity it could also increase this "chilling" effect? Thermal conductivity of air is very low, in fact in some instances it's used as an insulator (think some double pane windows). However, aluminum's thermal conductivity is very high. What happens is that when you touch it, the heat from your fingers is transferred into the aluminum at a much faster rate.Your body senses the temperature of your skin, not of the aluminum, so when the heat from your body is being pulled away locally at a very high rate, it seems very cold. That said, as has been stated, you will never be able to achieve lower than ambient temperatures. In fact, in all honesty, getting your outlet intake charge to be within 10 degrees of ambient is incredibly unlikely. Air to air heat transfer is driven mostly* by the temperature difference between the two mediums (otherwise known as Log Mean Temperature Difference). So as you get close to ambient temps your heat transfer starts to go away and you just won't be able to change the temperature very easily. Water to air is a little different though. ;) *flow rates play a role in it too, but with the speed of a car always changing it's difficult to really put that into perspective. |
Originally Posted by SovXietday
(Post 49689141)
You pretty much got it, everyone else keeps kinda dancing around the science around it but it's all about the thermal conductivity.
I've seen people use ac systems to cool an air to water style core.
the small core is about equal to the size of the OEM ac core in the interior so it has no trouble maintaining constant cool temperatures, well below ambient. plus they have it setup where the compressor only activates under boost. I might use an electric motor to run a small ac compressor and see how well it works... imagine IATs well under ambient all the time. |
Originally Posted by wantboost
(Post 49690351)
I just skim read through this entire 15 page post. Lots of interesting discussion, mostly from 2012 and 2013 though. I'm considering buying a 18x8x3" core intercooler 28" in total length from Go-Autoworks, with 2.5" intercooler piping. It is supposed to handle over 500 horsepower. Does that seem reasonable, or should I get one longer in size such as 24x8x3" or so? It's supposedly a Garrett core or something similar.
I got an answer that the 18x8x3” core will definitely support 500+ HP.
So I’m going with that unless someone says otherwise. |
A few questions trying to resurrect this zombie:
Hmm. I remember a lot of those concepts put to use .. See my comments in Blue
Originally Posted by dalek
(Post 52556714)
