Direct Port Nitrous system?
Old Apr 13, 2004 | 04:54 PM
allmota1.8's Avatar
Default Direct Port Nitrous system?
i had a question what nitrous system should i go with? a direct port system? or the plate system?(will it only work on the gsr manifold?)which one should i get looking to go 11.??(i hope) ls/vtec b16a head 10:1 je pistons ctr cams....
Old Apr 13, 2004 | 04:58 PM
allmota1.8's Avatar
Default Re: Direct Port Nitrous system? (jkjb16a)
and hondata
Old Apr 13, 2004 | 05:00 PM
Ben Huynh's Avatar
If you're going with Hondata, go with a dry system and have Hondata control your fuel.
Old Apr 13, 2004 | 05:09 PM
allmota1.8's Avatar
Default Re: Direct Port Nitrous system? (ben@importparts.com)
Looking at the pro fogger kit? good bad?
Old Apr 15, 2004 | 11:40 AM
allmota1.8's Avatar
help?
Old Apr 15, 2004 | 12:11 PM
Griffin@Camtech's Avatar
the pro fogger is good and can still have hondata contol the fuel just set the chut off about 300 RPM below the rev limiter for safty reasons
Old Apr 15, 2004 | 01:01 PM
AROD's Avatar
pro fogger is the best way to go, and you can use hondata to retard the timing.
Old Apr 15, 2004 | 01:13 PM
DXK Eg's Avatar
Default Re: (1.83Tc)
i would say the Direct Port, because in the long run my will make more power and on the other hand it also has fuel sparying at the same time as nos is being spary...but its up to u...
Old Apr 15, 2004 | 02:40 PM
EVIL_AWD's Avatar
Default Re: (dynasty-x-motorsport)
Pro Race Fogger all the way. I wouldn't even consider anything else.
Griff
Jan 18, 2007 05:29 AM
philipwight
Nov 5, 2003 06:24 PM
madhatter07
Feb 27, 2003 10:17 AM
TypeR1558
Aug 10, 2002 10:36 PM
