dipstick problem
I have an ls/vtec turbo. My problem is that the manifold is a log and is blocking the dipstick. Making it pretty much impossible to check the oil. Has anybody encountered this problem before? Any suggestions to fix this? Thanks!
Re: dipstick problem
You dont want to run no dipstick. You'll shoot oil out on the manifold when boosting. Ask me how I know...
What brand & design log manifold do you have? Post up a quick pic.
Originally Posted by tegra1027
(Post 43887155)
1 Attachment(s)
I cant remember the brand... And actually im not even sure this is considered a "log" manifold.
You can bend it to make it work.
Originally Posted by Mattb16teg
(Post 43890531)
Maybe if you grind down the webbing it might fit and fyi the oil level should not reach the dipstick.
Just bend the handle portion out to the left under the manifold.
Originally Posted by lsef
(Post 43891568)
Lightning- i can bend the handle, I just cant get the dipstick back in the tube once its out... So that wont really do anything. Does anybody know if and how the dipstick tube comes out? |
If you are really having trouble, twist the oil dipstick tube (the tube that goes into the block) to a different rotation and you can have the dipstick opening facing on one side (either beside the power steering or beside the distributor). You can also take that tube out and bend it slightly if you need a steeper angle.
ok so it comes out then...... how does it come out? Is it threaded in?
It's pressed in. Pretty tight fit
I'm running a blox manifold which is similar. I would grind out that webbing and get a shallow headed bolt for the center of the manifold to free up some space. You will still probably need to bend the top handle portion of the dip stick to keep it out of the way.
I have very simular manifold i just bended the dipstick tube and it will bend a lot. i also put a slight bend on the thin wire portion. I went towards the ps pump so it sounds like it goes either way. aka a bi bent dipstick. lol
| All times are GMT -8. The time now is 03:24 PM. |
