Delphi and RC engineering fuel injectors
Old Aug 18, 2005 | 06:52 AM
88crxhfb16's Avatar
Default Delphi and RC engineering fuel injectors
anyone with any experience running either of these?
are they a direct fitment for B-Series?
which is better quality?
Old Aug 18, 2005 | 09:05 AM
Sprockets's Avatar
Default Re: Delphi and RC engineering fuel injectors (88crxhfb16)
Some Delphi injectors are Lucas injectors. RC injectors are Lucas injectors with their label on them.
To answer your other question, the Delphi/Lucas injectors need some of the plastic ground down on a lathe, or if you have a steady hand, a Dremel. RC injectors don't need any modification to fit the fuel rail.
Old Aug 18, 2005 | 09:32 AM
88crxhfb16's Avatar
Default Re: Delphi and RC engineering fuel injectors (USE2B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A &raquo;</TD></TR><TR><TD CLASS="quote">Some Delphi injectors are Lucas injectors. RC injectors are Lucas injectors with their label on them.
To answer your other question, the Delphi/Lucas injectors need some of the plastic ground down on a lathe, or if you have a steady hand, a Dremel. RC injectors don't need any modification to fit the fuel rail.</TD></TR></TABLE>
are the RC injectors quality performance wise?? good for turbo applications??
Old Aug 18, 2005 | 09:40 AM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">
are the RC injectors quality performance wise?? good for turbo applications??</TD></TR></TABLE>
Have you done any research? I would say that the majority of users out there use the RC injectors followed by the DSM or Precision. So to answer your question: yes. yes.
RACEPAK
Apr 29, 2010 01:42 AM
RACEPAK
Apr 29, 2010 01:41 AM
