Delphi 3 bar map sensor quality questions
" Due to a decrease in quality of the "Genuine" Delphi 3 bar MAP sensors due to moving production to China and cutting corners in their budget, we are now stocking a USA made GM Style 3 bar MAP sensor. This sensor meets the same calibration data and meets or exceeds all Delphi specifications. In the future, we will continue to stock the Genuine Delphi part (SNSR-03075) as a case quantity only purchase and will be stocking this sensor (SNSR-03074 in our standard price breaks). "
https://www.bmotorsports.com/shop/pr...oducts_id/1584
Personally I'd just spend the extra $20 and get either a Hondata or Omni MAP sensor. Don't forget that things will get slightly more complicated if the Delphi/GM MAP sensor isn't pre-definied in the Hondata settings (I'm pretty sure they removed the GM type MAP sensors as a drop down option):
Hondata s300 Programmable ECU Guide
tl;dr - Spend the extra $20 and save yourself a potential headache, IMO. Delphi would probably work but you have better options available.
