Dart Blocks....?
Okay, I messed up my GSR block pretty good - Not going to sleeve this block. and I cant seem to find a legit GSR block for under like 500$ or so. With Benson sleeves being about 1000$, plus having to ship it out. and wait. I am almost at the $1900 shipped price for a Dart block. I have a good GSR crank.
I know a while back people had some problems with these blocks, but I thought they did a re design of the block to correct some problems? I e-mailed dart and they said nothing needs to be done to the block except finish hone it (I got a hone and Torque plate it to seat the sleeves) Why do I need to seat the sleeves though?
Anyone have any big problems with these things? or problems at all? would you buy another one?
I believe Earl mentioned just going through and double checking to make sure there were no metal shavings and deburring a little bit to clean things up, but other than that they're good to go. Theres a user Pandahatch that runs one, PM him about it.
Dart seems to have improved on their finishing touches on their blocks... I followed Earl's notes regarding the prep work involved, but I noticed that most of the things Earl mentioned were no longer necessary.
I am running a 81.5mm stock deck Dart block... It was purchased around August of last year.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K »</TD></TR><TR><TD CLASS="quote">I don't think they are NHRA legal..........as far as I know??
Do you plan on running any events?</TD></TR></TABLE>
Hmm I got to go find my rule book, can anyone verify this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fknfast »</TD></TR><TR><TD CLASS="quote">the best thing i ever bought!!!! want more info just PM me!!</TD></TR></TABLE>
Same here
Same here
Plus they have some features that a sleeved block simply won't have like slightly larger passages for fluids, and I believe the caps are a litte bigger on the crank? Or maybe a harder metal for the caps?
Not to rain on anyones parade, but the dart blocks have been known for the sleeves to "settle" and drop down 1-2 mm causing major head gasket leaks. Not sure if this has been fixed with the newer blocks. but I know a few that had this happen in the older ones. I am not saying all dart blocks do this, but there are a few.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">Okay, I messed up my GSR block pretty good - Not going to sleeve this block. and I cant seem to find a legit GSR block for under like 500$ or so. ?</TD></TR></TABLE>
I told u .. u can have the extra gsr block i have layin around for $200 .. let me know kyle.. i owe u a favor anyways.. so consider it yours if u want it
Donny -
Donny -
yea buy that OEM GSR block.
I found one for $100.
Worse case is you could buy an LS block and the Eagle LS-vtak conversion kit and run that, much cheaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ValleySyder »</TD></TR><TR><TD CLASS="quote">
Donny -</TD></TR></TABLE>
Thank you man.... okay back to sleeved b18c1
