D2B turbo build
Old Dec 20, 2013 | 01:34 PM
92sihatch59's Avatar
Default D2B turbo build
hey guys recently started gathering parts for my d16z6/y8
D2B build.
d16z6 css block 75.5mm from cncwerx
supertech 10.5:1 pistons
manley rods
d16y8 head (stock for now)
skunk 2 intake manifold
str 70mm throttlebody
golden eagle fuel rail
fic 850cc injectors
hydro b series ls tranny (modified bell housing)
comp clutch D2B flywheel
comp stage 4 b series clutch
custom forward facing turbo manifold
garret 60-1
custom breather set up (speedfactory style)[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old Jan 27, 2014 | 03:53 AM
Default Re: D2B turbo build
Old Jan 27, 2014 | 03:55 AM
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jan 27, 2014 | 03:57 AM
mounted the b series bell housing to the block
[IMG][/IMG]
[IMG][/IMG]
and painted the bay
[IMG][/IMG]
[IMG][/IMG]
Old Jan 27, 2014 | 04:30 AM
David Karney's Avatar
how much did you pay for the manly rods?
Old Jan 27, 2014 | 04:57 AM
$330
Old Jan 27, 2014 | 05:15 AM
where did you buy them from ... like on line or local .... do you feel there are better then eagle or are they just the ones you bought
Old Jan 27, 2014 | 06:24 AM
i ordered them through nolimitmotorsports.com and as far as quality in my own opinion i think they are better than eagle rods considering they are almost the same price
Old Jan 27, 2014 | 10:01 AM
wantboost's Avatar
Who is Mr Robot?
looks like a solid build with quality parts, plus it's obvious you're taking the time to do it right the first time.
as far as the rods, I've used Manley rods and Eagles, I prefer the Manley rods... quality rods made in the US, Manley stands behind their products 110%
Old Feb 14, 2014 | 05:46 AM
couple of updated pictures finished puttin the motor together and bolted it to the b series tranny and put it in the car tim to start the fabrication part of the build.
[IMG][/IMG]
[IMG][/IMG]
Old Feb 14, 2014 | 08:14 AM
gutted-dx's Avatar
Wow, this is gonna be fucken sick! Why did you pick the LS trans over B16/GSR?
Old Feb 14, 2014 | 09:01 AM
turbo sol's Avatar
more pics of the trans mounted!
Old Feb 14, 2014 | 12:21 PM
got the ls trans for cheap money but i just picked up a gsr tranny so im gonna build that and use it and i will update with more pick of the tranny and bell house mods
Old Feb 14, 2014 | 12:42 PM
91b18a1ls's Avatar
Nice. That block looks solid!
Old Feb 14, 2014 | 08:42 PM
OldSkoolDa91's Avatar
looks really good so far. i gotta follow this one!
Old Feb 14, 2014 | 11:21 PM
wantboost's Avatar
Who is Mr Robot?
please don't use that tee to supply oil to the turbo... the oil leaving that port is unfiltered and will cause premature turbo damage.
either run an inline serviceable filter on the feedline or get a sandwich plate, the ports on a plate supply filtered oil.
Old Feb 15, 2014 | 09:38 PM
Hidenplanvew's Avatar
what engine mounts did you use?
Old Feb 16, 2014 | 06:03 AM
i used regular b/d mounts for a eg with the 3 post timing belt side mount but running the b series tranny it pushes the whole swap over to passenger side 1" so i made a billet spacer between the post mount and block
Old Feb 16, 2014 | 10:30 AM
mrbigg9032's Avatar
Been using a similar tee on my gt30r y8 for about 4 years.......No issues at all..
Old Feb 16, 2014 | 12:20 PM
cbustuner's Avatar
You sure that tee is feeding unfiltered oil? The oil pressure sensor port on d-series motors is directly after the oil filter...
Nice build!
Old Mar 3, 2014 | 08:17 AM
aznlaoboi315's Avatar
Any updates? What did you do on the driver side mount bracket? spacers and longer bolts?
Nice build I want to D2B but without a plate
Old Mar 3, 2014 | 06:53 PM
kmihalcik1234's Avatar
Nice build, will stay tuned to see finished product
Old Mar 5, 2014 | 05:18 AM
Icon3 Re: D2B turbo build
have a few updates gonna take some new pictures this weekend started the fab work pretty much have the the cold side pipe made just needs to be finish welded and next step gonna start building my forward facing turbo manifold
Old Mar 5, 2014 | 05:20 AM
i made a billet spacer for the timing belt side mount with longer bolts
Old Mar 5, 2014 | 08:07 AM
KevinEF7's Avatar
I love that block, wish I went that route with my backup motor
