d16y8 vs b18b1 on boost
im here brainstorming on wheather i should fully build a b18b1 or a d16y8...one is vtec the other is non vtec...one has torque the other one doesnt...one is dohc other is sohc...one is cheaper than the other...so guys help me out here...will i create more power on lets say 12 psi...what motor will do better numbers and what will be easier and more reliable...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">D16 + boost =
B18 + boost > D16 + boost
(I own a boosted D16 too
</TD></TR></TABLE>B18 + boost > D16 + boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG »</TD></TR><TR><TD CLASS="quote">
)</TD></TR></TABLE>
It really depends which one is better.
D16 advantages:
Cheaper
Lighter
Less fricitional losses and rotational mass
Valve angles allow for more radical lift cams
B18 advantages:
Slightly more displacement
Independant adjustment of intake and exhaust cam timing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">This is a joke right? I mean yeah sohcs are cheap and all but if given a choice who would ever choose a D over a B?</TD></TR></TABLE>
Me.
)</TD></TR></TABLE>It really depends which one is better.
D16 advantages:
Cheaper
Lighter
B18 advantages:
Me.
D16 advantages:
Cheaper
Lighter
B18 advantages:
Slightly more displacement</TD></TR></TABLE>
Ahhem, define 'slightly'? 1590cc vs. 1834cc seems like a pretty nice chunk of real estate comparitivley.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
You forgot:
TORQUE
TORQUE
TORQUE
All things <U>equal</U>, you will ALWAYS make more power with an LS vs. a D16. And considering I've seen LS's for as little as $100 for a full longblock (like the one under the hood of my Integra now), the price advantage isn't quite today what it was maybe 2 years ago.
Another couple advantages of the LS which is just naitive to B-series, equal length axels
, and a useable variety of tranny selections (GSR, B16 etc..).
D16 advantages:
Cheaper
Lighter
B18 advantages:
You forgot:
TORQUE
TORQUE
TORQUE
if u are going for the most whp possible on pump gas, and still want to retain streetability but dont mind swapping engines, b18b is the way to go.
im staying d16 in my car just for the sake of having a turbo-sohc. lol, if u want to go fast on a budget and still dont mind swapping engines, b18b will make alot more hp, built or unbuilt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickromeo »</TD></TR><TR><TD CLASS="quote">no one seems to mention that ANY b series revs better than a d16, including b18b,</TD></TR></TABLE>
Not quite. Stock D16Z6 has an OEM red line of 7200rpm, even the Y8 has a 6950rpm limit. Stock B18A/B had only a 67 or 6800rpm redline. And if you'd ever really paid attention to the rocker setup on an LS, you'd prolly be scared to rev one high too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC »</TD></TR><TR><TD CLASS="quote">
244cc isn't ****. You should know that, you own both a Honda and Trans Am WS6.
You forgot:
TORQUE
TORQUE
TORQUE
, and a useable variety of tranny selections (GSR, B16 etc..).</TD></TR></TABLE>
You can get equal length axels for a D Series, I believe it's the ZC axels that you can use, but I could be wrong on that. Also in the world of forced induction with all things being equal both engines will have close to the same potential. For example an SC50 is good for a maximum of about 400whp whether it's on a B18 or a D16.
You forgot:
TORQUE
TORQUE
TORQUE
, and a useable variety of tranny selections (GSR, B16 etc..).</TD></TR></TABLE>You can get equal length axels for a D Series, I believe it's the ZC axels that you can use, but I could be wrong on that. Also in the world of forced induction with all things being equal both engines will have close to the same potential. For example an SC50 is good for a maximum of about 400whp whether it's on a B18 or a D16.
My y8 went 7200, and my current B18b also goes 7200. And no im not afraid to rev it that high.
</TD></TR></TABLE>My y8 went 7200, and my current B18b also goes 7200. And no im not afraid to rev it that high.
That's a rather silly contrast. The key here is RELATIVITY. 244cc means alot when you're comparing engines this small, infact we're talking about what.. an aprox. 20% increase in displcement from a D16? You don't think 20% more air and 20% more fuel mean something?
The issue here is boost pressure. I have no issues with pushing a stock B18B to 15psi and see 300+whp, but you and I both know that even with the same setup, a D16 will need ALOT more air to see 300whp in stock form (if it'll even get there), so no.. it's NOT equal at all.
Like I said, all things equal, the B-series is the power maker, period.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">
My y8 went 7200, and my current B18b also goes 7200. </TD></TR></TABLE>
Not sure where you're going with this?
My Y8 went to 8500 (accidently of course, but it did see ~8k multiple times and still runs today), that's not the point. Somebody said the D16's don't rev as high, and I simply pointed out that even in OEM trim there are SOHC's that rev higher than the LS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">And no im not afraid to rev it that high.</TD></TR></TABLE>
Ever had an LS rocker literally 'fly' off the valve? I did..
</TD></TR></TABLE> tell that to anybody that went from a 1.8L to a 2.0L and you will probably get laughed at
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">This is a joke right? I mean yeah sohcs are cheap and all but if given a choice who would ever choose a D over a B?</TD></TR></TABLE>hahahahahaha
thats going in the sig
)</TD></TR></TABLE>
same here. 7psi on my ls was very noticeable difference than 7 psi on my z6, not to mention you can make close to 100whp more on a stock ls safely than you can a d16.
i revved both to 7500. i was not going any higher on the ls, i would on the z6, but it wouldnt matter unless i was continuing to make power up there
)</TD></TR></TABLE>same here. 7psi on my ls was very noticeable difference than 7 psi on my z6, not to mention you can make close to 100whp more on a stock ls safely than you can a d16.
why is everyone talking about rev limits.
he said he is fully building either motor. both motors can rev 9k + with built heads.
if this is your 1st build, i would pick the SOHC, like you said its cheaper. if you blow something up, not such a dent in the wallet.
what are your power goals. 300, 400, 500 whp ? both motors fully built will get you there.
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">Me.</TD></TR></TABLE>
Don't get me wrong, I love D motors. I'll probably keep screwing with them for a couple more years at least. Bottom line, B series motors have more potential and are just downright stronger (stock) and are going to hold up to boost better...
well im aiming somewhere between 300 and 400...well yes i know a b18 has more displacement than a d16 but one has vtec.. vtec helps u alot top end but then displacement and an extra cam will also...and one other thing...i know for a fact that a stock ls sleeve will hold 400 hp but a d16 ima have to buy a sleeved block..i know a couple of ppl that have blown stock sleeves on d16 at those numbers....so basically i just wanna know whats a better deal..come on factory ratings say that d16 is rate at 127 and b18 @ 142...and boost will help out vtec alot so i would think it would over come the ls in the long run..but then again ls ive heard is an awesome engine to build...
