D16 turbo manifold?
Old Sep 7, 2004 | 01:04 PM
strahd_zarovich's Avatar
Default D16 turbo manifold?
Can a manifold from a D16 be made to fit a B18B?
Old Sep 7, 2004 | 01:39 PM
tgreaves's Avatar
Default Re: D16 turbo manifold? (strahd_zarovich)
If you cut the deck plate off and make a new one for the b18b then maybe.. Im not sure if the tubes will line up or not..
Is this a cast or tubular manifold?
Old Sep 7, 2004 | 01:47 PM
beepy's Avatar
Default Re: D16 turbo manifold? (tgreaves)
Not going to work well. Even if you remove the flange the tubes will be way off.
The port spacing is just too different:
D-series: 85-85-85
B-series: 90-80-90
Old Sep 7, 2004 | 02:40 PM
mamaboy's Avatar
i've seen it done on a b18b with the d16z6 apexi kit. try taking the head gasket and putting on the manifold...the way it would be installed. see if you can port out manifold inlets. If I remember correctly that's how it was done to fit the manifold.
Old Sep 8, 2004 | 10:12 AM
sethm's Avatar
Default Re: D16 turbo manifold? (mamaboy)
wasn't there some older posts about someone using a d series greddy kit on a b16?
Old Sep 8, 2004 | 10:35 AM
Bserieskllr's Avatar
yea but they used a bseries manifold.
Old Sep 8, 2004 | 12:11 PM
I thought so, someone was trying to sell me a D16 HKS kit for my B18 and I wanted to make sure first.
Sohc Driver
Feb 14, 2003 07:06 AM
nsxmatt
Jan 18, 2003 08:06 PM
2SLO
May 23, 2002 01:42 PM
