D16 Turbo Build, HELP me on my first build please
Old Mar 2, 2012 | 03:48 PM
  #26
apexi_rsx's Avatar
Default Re: D16 Turbo Build, HELP me on my first build please
most turbo kits do not come with garret turbos but the edelbrock kit with the gt28r or the greddy kit with a t25. best place to look for a reliable turbo kit is go-autoworks.com. as for methanol injection its not a necessity.
Old Mar 2, 2012 | 03:52 PM
  #27
98.4DR.EK.D16's Avatar
Icon2 Re: D16 Turbo Build, HELP me on my first build please
okay not a necessity, i see, but for the future would that be a good mod that will add hp? or just not worth the bother at all
Old Mar 2, 2012 | 03:53 PM
  #28
grumblemarc's Avatar
The Grumpiest
Originally Posted by 98.4DR.EK.D16
doesnt the meth kit add alot of hp by cooling?
You shouldn't need to ask ME if you did your research.
Old Mar 2, 2012 | 04:07 PM
  #29
im asking for your knowledge, with my research i saw that it says id "gain around 50 whp by cooling "
Old Mar 2, 2012 | 04:12 PM
  #30
The Grumpiest
But why do you need it if this is just a 350hp build? Overkill.
Dude. Go to the place that will be tuning this and talk to them.
Old Mar 2, 2012 | 04:13 PM
  #31
chewyv's Avatar
pm4nudes
Didn't I tell you to take everything off that list? First off you gave us a goal already, 350 to the wheels. Next, your state's laws regarding emissions. If your state has them, I can't help you. If not, you're golden.
Old Mar 2, 2012 | 04:15 PM
  #32
98civdx's Avatar
Master Detailer
http://www.go-autoworks-store.com/gocotuki.html
Old Mar 2, 2012 | 05:01 PM
  #33
its FL but i mean i dont really care lol
Old Mar 2, 2012 | 05:11 PM
  #34
The Grumpiest
Find a reputable tuner and talk to them.
Old Mar 2, 2012 | 05:20 PM
  #35
Originally Posted by D16SiHatch
d16 block with vitara pistons
One thing i can tell by the items you have listed is you have a **** TON of reading to do yet before you think about purchasing anything. None of us woke up with this knowledge one day, you just have to research and learn.
why are the 1000cc injectors too big?
Old Mar 2, 2012 | 05:28 PM
  #36
The Grumpiest
Even though they can't hurt they are overkill. If you're going to question every suggestion we give you just end the thread now.
Old Mar 2, 2012 | 05:49 PM
  #37
okay so i talked to Guessohw (built the car that im basing my build on) and came up with this parts list. any info or comments would be appreciated
y8 vtec head thats ported and polished with retainers and springs
aem stage 4 cam and aem cam gear
eagle rods
gates racing timing belt
throttle body thats ported and polished
72 mm throttle body
1000cc injectors and aem fuel rail (only because it costs the same as the 750cc)
oem honda gaskets
arp head studs
oem fuel pump
walbro fuel pump
msd distributor
4 bar map sensor
electronic boost control
ex transmission
any suggestions? am i missing anything or should i exchange something for something else?
Old Mar 2, 2012 | 05:51 PM
  #38
The Grumpiest
Bearings.
Old Mar 2, 2012 | 05:58 PM
  #39
Bearings.
YES! you are correct i just realized im missing 3 things
bearings (any in particular?)
clutch (i was told act is good and cheap)
and motor mounts (any in particular?)
Old Mar 2, 2012 | 06:00 PM
  #40
The Grumpiest
ACL.
Motor mounts are not necessary but couldn't hurt. Hardrace is what I run.
Clutch. Exedy. Get the clutch that will hold the power. Don't buy into that "Stage" crap.
Old Mar 2, 2012 | 06:35 PM
  #41
ACL.
okay thank you so much
should i get a whole bearing kit? like this one?
http://www.ebay.com/itm/ACURA-HONDA-...sories&vxp=mtr
or is this all i need?
http://www.ebay.com/itm/ACL-Race-STD...sories&vxp=mtr
Old Mar 2, 2012 | 06:40 PM
  #42
Alfa Q the 2nd's Avatar
stock rods (should i change them to eagle?)(is that neccessary?
I have blown stock z6 rods at 16psi and blown them at 8psi so I would replace them.. If you go with H-beam you will have to notch the block
http://www.theoldone.com/articles/d_...building_tips/
y8 vtec head ported and polished with retainers and springs.
stage 4 aem cam and aem cam gear
hes selling me all that for 750 (good buy?)
I have over a grand in my head alone, and its not ported and polished. Yes I would say good buy.
Stage 4 cam? Are you going to drive this on the road? or is it for the track only. With a stage 4 cam your idle will be f@%ked.
If this is going to be a street car I would go stage one or 2.
individual throttle body ported and polished- 300
72 mm throttle body -100 (should i get a throttle body spacer?)
So you have or want an ITB.?
ITB are not for boost. I would just go with a Skunk2 intake manifold and no bigger then a 70mm TB. Too big of a TB can possibly chock the engine out.
1000cc injectors and aem fuel rail- 560
Anything bigger then 660 on a D16 is just crazy, there is no need for it.
oil pump- ive heard i should get a ported and shimmed oil pump?
Yes port the oil pump and shimming it will make create higher oil pressure this sometimes is not friendly to the seals. 1 shim should be OK, but keep an eye on it the oil pressure. Here is some info
http://www.onecamonly.com/showthread.php?t=478
walbro 255 fuel pump-115
Yes you want this but if want to utilize the 1000cc injectors you will need a bigger fuel pump. Again there is no need for injectors bigger then 660 on a D16.
next question, ive heard good things about hondata (good choice or not?)
Hondata has a lot of support and options. the s300 can be tuned on the fly, this is a major plus. If you got the bucks go for a AEM standalone.
I have eCtune, Its basically chrome modified. There are a lot of base maps you can download. Not as user friendly as Hondata but cheaper and gets the job done just as well.
Old Mar 2, 2012 | 06:41 PM
  #43
98civdx's Avatar
Master Detailer
aem stage 4 cam and aem cam gear Why stage 4? Do you have a link to the cam?
eagle rods
72 mm throttle body
oem honda gaskets
arp head studs
oem fuel pump
walbro fuel pump
msd distributor Noithing wrong with stock here.
4 bar map sensor
ex transmission
What are you going to do for tuning? You shouldn't need a fuel rail. What about a regular?
What are you going to do for the exhuast, open down pipe?
Clutch? Stock flywheel? Valve seals?
Old Mar 2, 2012 | 06:50 PM
  #44
SKAVENGER88's Avatar
power level goal would be around 350 whp
Where did u get this number from?
Old Mar 2, 2012 | 06:53 PM
  #45
ive seen the head block combo running and the idle is abit weird but not too bad, and yes its my dd
and no sorry that was wrong its not an itb its just ported and polished
only reason im planning on the 1000cc injectors and aem fuel rail is cus they come in a pack
so i should keep stock fuel rail (not a high flow one?)
and get 660cc injectors?
Old Mar 2, 2012 | 06:56 PM
  #46
honda-tech.com/showthread.php?t=2974744
im basing my build off of him and he made 348 whp
Old Mar 2, 2012 | 06:58 PM
  #47
The Grumpiest
Good answer.
Old Mar 2, 2012 | 07:06 PM
  #48
Then y r u wondering injector size read what he runs. Figure your trim size. 350 whp is a big number for a build u know nothing about
Old Mar 2, 2012 | 07:10 PM
  #49
stage 4 because it comes with the head im buying
tuning i was planing on hondata
fuel rail is only being upgraded cus it comes with the injectors
i was thinking exedy clutch
i was thinking of keeping stock flywheel
and idk about valve seals or open down pipes(more info plz)
your help is appreciated!
Old Mar 2, 2012 | 07:11 PM
  #50
he runs 1000cc injectors which is what ive been saying but everyone says theyre overkill lol
