d16 head studs on d15?
i have a 90 dx motor and am going to do a mini me swap with turbo. and i was wondering if theres a way i could put the d16 arp head studs on the d15.
anyone know? or know of a solution?
I used D16z6 ARP's on my D15b7. Only 8 out of the 10 studs fit. Both of the outside holes on the back row wouldn't go in so I had to use OEM headbolts for those holes. This was for a D16y8 head on a D15b7 block, so your results could vary....
really? i've used new honda d16z6 head bolts on my brothers dx coupe. they fit fine with no problems. maybe you just need to get your threads cleaned out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku »</TD></TR><TR><TD CLASS="quote">all 88-95 dseries use the same studs and bolts. as long as you are using any 88-95 head, they will work.</TD></TR></TABLE>
hmm are you sure? because i have been told that the 92 and up d series heads are slight different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid »</TD></TR><TR><TD CLASS="quote">
hmm are you sure? because i have been told that the 92 and up d series heads are slight different</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku »</TD></TR><TR><TD CLASS="quote">yes i am sure. i have done a mini-me before with an a6 block and a z6 head. i used z6 headstuds.</TD></TR></TABLE>
sweet! thanks man
sweet! thanks man
19civiclx95
Dec 7, 2005 10:10 AM
