d16 cometic headgasket
Old Sep 7, 2004 | 04:43 PM
safe driver's Avatar
Default d16 cometic headgasket
I searched but couldn't find anything...
Stock bore for D16 engines are 77mm, right? The smallest cometic hg is 77.5mm. Is this going to be a problem?
Anyone using cometic hg's on a stock bore D16y7?
thanks
Old Sep 7, 2004 | 04:50 PM
Slammd Sol's Avatar
Default Re: d16 cometic headgasket (safe driver)
75mm is stock. Cometic makes a wide variety from 75-79mm..
http://www.nipponpower.com/eng....html
Old Sep 7, 2004 | 05:00 PM
Default Re: d16 cometic headgasket (Slammd Sol)
oops. I meant 75mm as stock bore. don't know why i wrote 77.
it's weird though, i checked cometic's site and on their brochure 75mm is not listed.
but thanks for the heads up.
Old Sep 7, 2004 | 05:03 PM
ATS*Mark's Avatar
OG triple OG
i have a 75mm stock bore cometic on my y8.....
Old Sep 7, 2004 | 05:16 PM
Casey's Avatar
Default Re: d16 cometic headgasket (Hella_JDM)
my friend is...he got a .051 thickness high pressure one. It seems a lot thicker than stock but only lowered compression by .1 according to a comp calc i did. Either way, we mated it with arp head studs. On his greddy kit, y7 with y8 mani, the wg vac hose popped off, it hit 17psi a few times before we caught on to why it was so fast, and it still runs fine now that were back down to reasonable boost levels
Turbo_y8
Feb 15, 2006 10:26 AM
teal_dx
Jul 19, 2005 12:58 PM
xXx Justin xXx
Feb 29, 2004 02:11 PM
bey
Nov 18, 2002 02:31 AM
