d15b vtec stubles under boost
Old Oct 30, 2014 | 09:12 AM
NC_jdmeg's Avatar
Default d15b vtec stubles under boost
Just did my turbo set up amd it runs really well until after 5psi it starts stumblimg like its not getting enough fuel, the injectors are stock so it may be the case but just want to cover all bases and see if it could be something else any help is appreciated
Old Oct 30, 2014 | 09:26 AM
Schister66's Avatar
Man U FTW
Default Re: d15b vtec stubles under boost
Stock injectors and let me guess, stock ECU too? Stock fuel pump?
Old Oct 30, 2014 | 09:30 AM
NC_jdmeg's Avatar
No actually not stock ecu and walboro fuel pump, just gotta order injectors, and want to make sure its the problem but thanks
Old Oct 30, 2014 | 09:35 AM
Schister66's Avatar
Man U FTW
So you're driving it untuned (or on a basemap) on stock injectors?
Old Oct 30, 2014 | 09:36 AM
LTCxD2B's Avatar
Need more info bruhhhh
Old Oct 30, 2014 | 09:40 AM
LTCxD2B's Avatar
Needs moar infer bruhh
Old Oct 30, 2014 | 10:23 AM
NC_jdmeg's Avatar
Yea its base map and stock injectors, got a tune lined up hopefully monday, and injectors I need to get apparently, so the injectors are the problem?
Old Oct 30, 2014 | 10:25 AM
NC_jdmeg's Avatar
Only thimgs left stock on motor are injectors and fpr, but I was told by a few guys it should be ok for a while until I could get the new parts
Old Oct 30, 2014 | 11:18 AM
Schister66's Avatar
Man U FTW
Yes, you need larger injectors before you tune...there is no point in going unless you have larer than stock fuel injectors. Do you know which size injectors the basemap is for? Chance are, its not for stock ones which is why your car runs like crap
newtothescene
Apr 10, 2009 02:52 PM
russianswty
27
Nov 14, 2006 06:30 PM
TypeR0207
Feb 10, 2005 03:42 AM
