CTR cams?
Old Feb 20, 2006 | 08:31 PM
EJ8 GSR-T's Avatar
Default CTR cams?
How would CTR cams work with FI?
Old Feb 20, 2006 | 08:32 PM
SOHC_MShue's Avatar
Default Re: CTR cams? (userdead626)
good
Old Feb 20, 2006 | 08:58 PM
JDM00SI's Avatar
Default Re: CTR cams? (SOHC_MShue)
I will be running ITR cams, which are either the same or extremely similar to CTR cams depending on the year of CTR cams....
so very good.
Old Feb 20, 2006 | 09:36 PM
KillerBee18's Avatar
Default Re: CTR cams? (JDM00SI)
NA cams and FI cams are designed differently with lift and duration. A NA cam will have high lift with a duration that over laps so both valves are slightly opens at the same time briefly to cause a suction affect on the intake when exhaust gases are being pushed out which makes for the power gain. In FI setup you want high lift with a short duration so there is little or no overlap so the boost does not just flow in and out before it is even compressed in the chamber. IMO i would not use ITR cams or CTR cams in a FI setup the best stock cam shaft for FI setups are GSR cams AKA poor man's crower... lol. hope this info helps.
Old Feb 20, 2006 | 09:42 PM
beerbongskickass's Avatar
Default Re: CTR cams? (KillerBee18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerBee18 &raquo;</TD></TR><TR><TD CLASS="quote">NA cams and FI cams are designed differently with lift and duration. A NA cam will have high lift with a duration that over laps so both valves are slightly opens at the same time briefly to cause a suction affect on the intake when exhaust gases are being pushed out which makes for the power gain. In FI setup you want high lift with a short duration so there is little or no overlap so the boost does not just flow in and out before it is even compressed in the chamber. IMO i would not use ITR cams or CTR cams in a FI setup the best stock cam shaft for FI setups are GSR cams AKA poor man's crower... lol. hope this info helps.</TD></TR></TABLE>
ITR/CTR cams are defintely the way to go. I can find you plenty of 500+ whp hondas with either GSR or ITR/CTR cams.
http://forums.evans-tuning.com...=1623
phelpsj2
11
Dec 19, 2010 02:18 PM
SOLtrain "tiiiteboyee"
Mar 19, 2008 07:06 PM
crxh22project
30
Jul 24, 2005 02:24 PM
rev2ninetyper
Jul 21, 2004 04:08 AM
Drag_Dc2
Sep 2, 2001 06:56 PM
