crx intercooler piping
Old Mar 28, 2005 | 09:01 PM
camo_crx's Avatar
Default crx intercooler piping
can someone help me out ? all i need is intercooler piping to finish my car. but i cant find a kit made for my car. also can someone post some pics of their crx w fmic so i can get an idea of what the bends look like. i got some ghetto made pipes but there from an eg and dont fit. help meeeeee
Old Mar 28, 2005 | 11:25 PM
BlueShadow's Avatar
Default Re: crx intercooler piping (camo_crx)
Do you already have a manifold and turbo?
Every setup is gonna be different, but here is a pic of my Revhard kit. Maybe it will give you some ideas on how to route your piping. I like how Revhard welded an elbow on the compressor outlet. That way I just have a short elbow from the turbo to IC inlet and the IC outlet to TB is just that one other pipe. As you can see in the frontal shot my IC sits right on that lower frame. I had to hack away at the center support and cut a huge hole so the IC would go through the front part of the frame.
here are the pics...this was from when I was test fitting all my piping and stuff. And yes I know my radiator is not in the best place. It will be getting replaced in a weeks or so by a radiator that actually fits in the FR tracbar tabs.
Old Mar 28, 2005 | 11:39 PM
sporkcrx's Avatar
Default Re: crx intercooler piping (BlueShadow)
Mine goes up from the turbo, into the hole where the windshield fluid tank use to be, around to the intercooler, then up where the stock intake use to go.
Old Mar 28, 2005 | 11:56 PM
camo_crx's Avatar
what about some links to some pre fabed pipe kits
Old Mar 29, 2005 | 12:16 AM
sporkcrx's Avatar
Default Re: (camo_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camo_crx &raquo;</TD></TR><TR><TD CLASS="quote">what about some links to some pre fabed pipe kits </TD></TR></TABLE>
It depends on your set up. Intercooler, manifold, turbo, the way the turbo is clocked, etc. You probably won't be able to find something that is a direct fit.
Old Mar 29, 2005 | 12:47 AM
liam821's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">
It depends on your set up. Intercooler, manifold, turbo, the way the turbo is clocked, etc. You probably won't be able to find something that is a direct fit.</TD></TR></TABLE>
Yeah chances are you wont find something that is a perfect fit. What id recommend you do, is buy some 2.5" U bends, cut and mark the piping into the shape that pipes need to be. I taped the pipes together until i had the piping like i wanted them. Then i had a buddy tig weld them together for me.
U bends
Cut and tape together
After the were welded together
Install on car and go!
liam
Old Apr 15, 2005 | 03:17 AM
Ray-mond's Avatar
Default Re: (liam821)
OOOooo snaps thats a good *** ideal thats what I'll do thanx
Old Apr 21, 2005 | 09:41 PM
tuanhoprosk8's Avatar
Default Re: (1Guamracer)
dude.. sick. wher u get that piping and what kind of piping is that... what kinda welds u do
how much was it total for the piping
kreatekustomz
Dec 19, 2009 07:45 PM
J1A1H
May 10, 2007 03:36 PM
CO_CReX
Apr 4, 2007 04:47 PM
heyitzspikey
Dec 24, 2006 11:27 AM
camo_crx
Mar 29, 2005 05:23 AM
