critic my 1/4 time
Old Jul 26, 2003 | 06:18 AM
b18cTurbo's Avatar
Default critic my 1/4 time
car:civic 00 coupe full weigh 2850lbs whit me in
last night i tested my car at the trac just for fun and it goes like this,
my setup:tire R1 bf 215 60 14 at loaded at 14 psi
low boost at 8 psi 1st and 2d gear cuz of very limited traction at the trac and shitti tire 3rd and 4th high boost at 21 psi
and my best 13.32@124.76mph 0-60'' 2.3 R1 tire
at 8 psi only i did 14.3@104.8 mph 0-60'' 2.6 on falken azenis 205 50 15
question,if i had some good slicks whit full boost in 1st and 2d whats the potential of my car?
thx for any input
Old Jul 26, 2003 | 06:46 AM
Kataku2K3's Avatar
Default Re: critic my 1/4 time (sleeper007)
Should be good for low 11's, if you can hook up... With a 360whp stock sleeved B18C EJ6 on 12lbs. my friend has done a 11.60@121 on MT 24.5x9.0x13 slicks... Then again Brian's car made 536whp and 345wtq and only ran a 10.98@133 on those same slicks... The reason we don't run the 26's yet is because he's running a GSR tranny and the gearing is just to long with the extra rollout... We're going to swap trannies in about 15 mins on Duc's and Brian's car so we'll see what they can do today... Good Luck, you'll get down there... Latez
Poop111444's Avatar
I've seen cars do 11s with 124 MPH trap speeds
Old Jul 26, 2003 | 06:59 AM
b18cTurbo's Avatar
Default Re: critic my 1/4 time (si_mekanik)
would 24.5 slicks whit itr tranny and 8500 cut off good for 130mph?
Old Jul 27, 2003 | 10:45 AM
Kataku2K3's Avatar
Yup, you should be able to do that so long as it's not a '98 spec+ JDM ITR with the 4.785 FD... Brian can run his 133mph traps with his straight GSR tranny and reving to ~8500 in 4th on his 24.5's... Latez
browniiiz
Nov 6, 2008 12:26 PM
Samuels
Mar 11, 2007 02:37 PM
nvmyb20hatch
Aug 29, 2006 11:42 AM
99lspwr
Oct 7, 2003 06:45 AM
xxplosif1
Oct 17, 2002 08:44 AM
