crankshaft heat treating
Old Sep 29, 2010 | 09:11 AM
90 integra da's Avatar
Default crankshaft heat treating
Question for the smarter people here on H-T. I spun a rod bearing on my ls and am re using the old crank. When the machine shop was fixing it the guy told me it was scored up pretty bad and that it wore through the heat treating, so he recommended getting it re heat treated after he is done. Do any of you guys know if this is necessary to do?
Old Sep 29, 2010 | 09:19 AM
kyden's Avatar
Default Re: crankshaft heat treating
i would just find another crank. just me though.
Old Sep 29, 2010 | 09:20 AM
Muckman's Avatar
Moderator in Chief
Throw it out. Its not cost effective to fix the old crank when you can buy a used crank in good condition for about $100.
/thread
Old Sep 29, 2010 | 09:23 AM
unusual71's Avatar
if it is heat treated it was done before the mains were ground to size in the factory. Nothing you could do now but send it to a machine shop to be re treated and then ALL the mains would have to be reground.
+1 on the Get a new crank solution. something that caused that much damage has altered the material properties. These cranks are fairly cheap anyways no reason to save one this bad.
Old Sep 29, 2010 | 09:49 AM
Thats what I'm thinking but the machine shop told me it can still be saved and the re heat treating only adds another hundred bucks so idk what to do. I'm probably gonna end up getting a used one I suppose. Do you guys recommend getting a used crank and just using it as is or would you recommend it to be micro polished?
Old Sep 29, 2010 | 09:58 AM
NonovUrbizniz's Avatar
Loved
Buy a "new" crank... DO NOT try to salvage a honda crank that's worn through the hardened journals.
Old Sep 29, 2010 | 09:59 AM
Muckman's Avatar
Moderator in Chief
Get a used LS/CRV crank that was pulled from a good engine with no journal damage.
You dont have to but you can have it micropolished and [re]balanced.
Old Sep 29, 2010 | 10:00 AM
ok so silly question that im 99% sure of but a b18b crank is the same as a b18a correct?
Old Sep 29, 2010 | 10:03 AM
Muckman's Avatar
Moderator in Chief
Yes. Both 89mm stroke.
Old Sep 29, 2010 | 10:08 AM
cool, thanks for the fast replies guys. looks like i found a local guy selling one that was just pulled out of a healthy motor so this turned out not so bad.
leroyb
Apr 17, 2009 10:14 PM
japscrap
Jan 31, 2009 07:11 PM
Mr Tickle
Dec 8, 2008 09:25 AM
94-integra-ls
Feb 7, 2006 07:23 PM
bboy_gangsta
Feb 15, 2003 03:42 PM
