CP piston Ring Gap
Old May 18, 2012 | 08:17 AM
  #26
Dc4LsTeG's Avatar
EK9
Default Re: CP piston Ring Gap
.015" isnt big, that should be your smallest ring gap
Old May 18, 2012 | 04:57 PM
  #27
11SECEG's Avatar
Originally Posted by boosted_D
Gaps are larger to allow blow by so cylinder pressures stay under control and everything stays free moving. Too tight of clearances and you crack rings/pistons.
You should think about ptw clearance as well with that much power.
Ptw of .040 to .050
Top ring .020 to .022
Middle ring .024 to .026
you meant .004 to .005 right??? lol
Old May 19, 2012 | 04:00 AM
  #28
Steeve_Civic's Avatar
Yes, but going to put .015 for the PTW
Old May 19, 2012 | 05:53 AM
  #29
blackeg's Avatar
.005 to .006 of an inch for ptw
Old May 19, 2012 | 11:07 AM
  #30
Dc4LsTeG's Avatar
EK9
X2 you dont want .015 for ptw. Thats stock specs, youll have a problem if you try and do that
Old May 20, 2012 | 01:04 PM
  #31
for the PTW on this link CP say .015 min, even for DRAG Racing why?
http://cppistons.com/LinkClick.aspx?...D0%3d&tabid=74
Old May 20, 2012 | 01:16 PM
  #32
Dc4LsTeG's Avatar
EK9
The link doesn't work but .015 is for the min oil gap ring
Old May 20, 2012 | 05:05 PM
  #33
blackeg's Avatar
many piston manufacturers under estimate the required piston to wall for higher hp hondas..
Old May 20, 2012 | 06:25 PM
  #34
Dc4LsTeG's Avatar
EK9
.015 would be a huge ptw though not to tight
Old Jun 15, 2012 | 03:57 PM
  #35
civic-steve-94's Avatar
i know no one probably cares but after some nice need driving my rings finally seated damn nitrate coated rings
Old Jun 15, 2012 | 07:34 PM
  #36
eg:R's Avatar
How many miles did it take you?
Old Jun 18, 2012 | 11:13 AM
  #37
well since my speedo works when it wants to i can only guess at about 800 miles but i was told that those rings were suppose to seat within a couple hundred miles
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
bradabu
Aug 12, 2011 05:18 AM
Rootie524
Jul 11, 2011 07:57 PM
thegatekeeper14
Jan 18, 2011 04:18 PM
95blackEG
May 23, 2007 02:50 PM
