Coolant overflow tank.. umm overflowing
Old Apr 23, 2004 | 12:26 AM
Sivik's Avatar
Default Coolant overflow tank.. umm overflowing
hey,
my coolant overflow tank isn't gushing out constantly... it just seems to fill up on its own when i drive hard, and sometimes overfills and i had a little bit of coolant spray over piping and block? any idea why this is happening? i never filled it past the MAX line so I dont think there's too much coolant, but just the tank keeps getting higher. if i drive normal for a day or so it goes back down a little bit. plz help. thanks!
Old Apr 23, 2004 | 04:55 AM
Dr Honda's Avatar
Default Re: Coolant overflow tank.. umm overflowing (Sivik)
easy... I have 3 words for you.
Blown Head Gasket.
fix it before you get anti-freeze in your oi, and mess up your engine
Old Apr 23, 2004 | 08:09 AM
ek9turbo's Avatar
Default Re: Coolant overflow tank.. umm overflowing (Dr Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Honda &raquo;</TD></TR><TR><TD CLASS="quote">easy... I have 3 words for you.
Blown Head Gasket.
fix it before you get anti-freeze in your oi, and mess up your engine</TD></TR></TABLE>
couldnt say it any better
Old Apr 23, 2004 | 08:21 AM
DaX's Avatar
DaX
Loved
Community Favorite
My friend trashed his headgasket less than a month after we noticed his coolant reservoir overflowing.
Old Apr 23, 2004 | 08:58 AM
Turbo E's Avatar
Blown Head Gasket.
same here. stop the car and hear "blub-blub-blub" from the overflow bottle.
Old Apr 23, 2004 | 09:39 AM
4-banging's Avatar
Blown Head Gasket.
yeaP
Old Apr 23, 2004 | 10:00 AM
project dc2's Avatar
Default Re: Coolant overflow tank.. umm overflowing (4-banging)
i 5th that motion !
Old Apr 23, 2004 | 10:04 AM
RTW DC2R's Avatar
6th! same thing on my civic. thought it was overheating bc the radiator or therm was toast, replaced them, same crap happened. does it smoke at all yet?? if it doesnt, it probably will soon. replaced my head gasket, problem solved.
Old Apr 23, 2004 | 10:12 AM
Mad Cow's Avatar
Old Apr 23, 2004 | 11:03 AM
Sivik's Avatar
wow, head gasket sounds nice... advice on one? Greddy 2mm? i supposedly have some smoke coming out of my exhast so im guessing thats it.
is it ok to drive my car NOT hard until i replace the head gasket?
Old Apr 23, 2004 | 12:04 PM
quikB18B's Avatar
Default Re: (Sivik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sivik &raquo;</TD></TR><TR><TD CLASS="quote">
is it ok to drive my car NOT hard until i replace the head gasket?</TD></TR></TABLE>
I had the same symptons 3 years ago when I didnt know much, It took about 6 weeks of driving it like that for the motor to finally blow
Moral of story dont waste any time a Headgasket is cheaper than a rebuild
Old Apr 23, 2004 | 12:14 PM
CRX T-Si's Avatar
Default Re: (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sivik &raquo;</TD></TR><TR><TD CLASS="quote">hey, my coolant overflow tank isn't gushing out constantly... it just seems to fill up on its own when i drive hard, and sometimes overfills and i had a little bit of coolant spray over piping and block? any idea why this is happening? i never filled it past the MAX line so I dont think there's too much coolant, but just the tank keeps getting higher. if i drive normal for a day or so it goes back down a little bit. plz help. thanks!</TD></TR></TABLE>
It's your radiator cap that is bad. The sypmtoms sound right to me.
If you take your radiator cap off you should see oil residue, that is if you have a blown head gasket.
Change your radiator cap first and see if that happens again. Alot cheaper.......
Old Apr 23, 2004 | 03:17 PM
Sivik's Avatar
ok ill try the cap first.
i looked at my oil as well and its not milky either.
Old Apr 24, 2004 | 11:41 PM
coil222's Avatar
ah crap, my integra is doing this too (na), I guess its time for a new radiator cap and a compression test.
I just refilled my radiator using the coolant overlfow tank - no oily mess/residue that I can see.
Modified by coil222 at 4:37 PM 4/25/2004
Old May 5, 2004 | 03:31 PM
coil222's Avatar
compression test 205-210 across the board
mugen rad cap, thermostat and fan switch should be here any any day now.
Old May 5, 2004 | 04:41 PM
PrecisionH23a's Avatar
Default Re: (coil222)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coil222 &raquo;</TD></TR><TR><TD CLASS="quote">compression test 205-210 across the board
mugen rad cap, thermostat and fan switch should be here any any day now.</TD></TR></TABLE>
Compression tests dont mean ****. I had the overflow tank problem a few years ago and I yielded perfect compression. Yanked the head and found the HG was blown. At least do a cyl leakdown test as well. Those are far more accurate but unfortunately can be misleading as well.
Yank your plugs and see how they look. You typically will see a 'whiter' plug in reguards to the location of the blown headgasket. Also, I don't recommend boosting on a blown headgasket. You are allowing coolant to enter the combustion chamber which will in change let you run lean and increase your combustion temperatures. What does that mean? Melted pistons usually on the intake side.
You also need to check the decking of the head and the block to make sure no warping occurred. Usually this will happen near one of the water jackets.
Old May 5, 2004 | 04:45 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (PrecisionH23a)
same thing happpend to me , changed the hg and arp studs , problem solved
Old May 5, 2004 | 05:04 PM
5thgencivic's Avatar
Default Re: Coolant overflow tank.. umm overflowing (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">
same here. stop the car and hear "blub-blub-blub" from the overflow bottle. </TD></TR></TABLE>
haha, exactly... Same thing would happen with my coupe. I beat it for like 2 months like that. It's not boosted now, but still running like 6 months later
Old May 5, 2004 | 06:09 PM
coil222's Avatar
plugs:
http://coil222.no-ip.com/images/plugs1.jpg
http://coil222.no-ip.com/images/plugs2.jpg
http://coil222.no-ip.com/images/plugs3.jpg
I'm not boosted, I just found this thread via a search and thought that I should jump in.
Coolant does not look oily, and Oil change was done about 3 weeks ago and it didn't look watery.
If it means anything i went from getting about 280 miles per tank gas to about 200 miles per tank of gas about a week ago.
Old May 6, 2004 | 06:00 PM
coil222's Avatar
bump
Old May 6, 2004 | 06:20 PM
Mulan's Avatar
i had the same sympton, i passed my compression test, retorqued arps 85lbs, bleed radiator and re-bleed radiator, changed water pump, ran without thermostat and eventually ran a new 1, constant on radiator fan, & on & on... i was also supposedly running one of those badboy blowproof headgaskets... Yeah whateva, somewhere between na & 1st lil' lb of boost i began having coolant problems... i'm ramblin'now... 2make long tedious story short. i finally took my head off and found cluprit --&gt; blown head gasket &lt;-- now I'm boostin`the hell out of my OEM HG & coolant problem free 2this day PrecisionH23a thanks a mil
Modified by Mulan at 9:31 AM 5/9/2004
Old May 6, 2004 | 07:55 PM
tilt's Avatar
ive had the same problem happen to me. it was a defective radiator cap.
Old Aug 30, 2016 | 02:11 AM
Akfranklin2014's Avatar
So I have this same problem in my 2000 Honda Civic LX, but I've already had the head gasket replaced. It stopped overheating for a bit and then started back up again. Thermostat and water pump have been replaced as well. Coolant keeps coming out of the reservoir tank.
Old Aug 30, 2016 | 06:53 AM
TheShodan's Avatar
Moderator
Are you using new OEM head bolts when you replaced it, or the same ones?
The bills may have stretched over the years, and once you remove the head may not go back to spec as they once were
Old Sep 1, 2016 | 04:50 PM
slomofo's Avatar
GDD Member
List all relevant conditions.
Do your fans work?
With engine running and radiator cap off. Do the bubbles in the radiator ever go away?
Did you do any machine work to the head or did you just toss a new gasket in there and call it good?
Proper torque specs on head gasket?
Just throwing this out there in case you didn't pick up on it, but I was born the same year this thread was created.
