Compressor wheel hits housing
Old Apr 21, 2006 | 10:27 AM
wpgcivic's Avatar
Default Compressor wheel hits housing
my 60-1 has a little bit of shaft play on it so you can see a tiny bit of grinding on the compressor housing from the turbine...i just want to use this turbo for about 3 months, is there anything i can do for the time being?
Old Apr 21, 2006 | 01:26 PM
shortyz21's Avatar
Default Re: Compressor wheel hits housing (wpgcivic)
yeah run it. other then new bearings, and a new wheel + balancing. which is more then a new 60-1.
if it hit already the wheels gimped already, maise well run it till it dies
Old Apr 21, 2006 | 04:57 PM
wpgcivic's Avatar
can i sand a little of the compressor housing on the inside where its hitting so that there isnt any contact made or will that screw up the cfm?
Old Apr 21, 2006 | 06:10 PM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">my 60-1 has a little bit of shaft play on it so you can see a tiny bit of grinding on the compressor housing from the turbine...i just want to use this turbo for about 3 months, is there anything i can do for the time being? </TD></TR></TABLE>
the turbine is on the hot side. how can the turbine be grinding the compressor housing? im confused.
but anyways... it sounds like your turbo is shot and you shouldnt use it.
ninjaturtleEG
Jun 18, 2012 02:04 PM
TegR
Feb 26, 2007 01:51 PM
joshwhe
Dec 31, 2003 07:48 AM
ludelvr
Oct 16, 2002 01:55 PM
Stock@$$GSR
Apr 18, 2002 06:22 AM
