compression ratio help
I need some help finding my compression ratio of this setup.
b18a1 block with CP Gsr pistons compression 9.0.1 compression height 1.181 cp part number is CP7010.
integra LS eagle rods
block was decked for gasket sealing about .010 over
B16 head, shaved .040 over
head gasket stock thickness.
whats the compression ratio with this setup?
I order a cometic .051mm head gasket to be safe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">9.5:1</TD></TR></TABLE>
thats with the stock head gasket correct?
is that accurate?
is that accurate?
You said you ordered a .051 cometic gasket.You should measure the combustion chamber to get accurate results.You should give CP a call and find out the volume of the piston dish as they don't list it on their website.
SiMateoAko
Sep 1, 2005 09:06 AM
