Components in a nitrous system (technical)
Old Jun 23, 2006 | 01:33 PM
done's Avatar
Default Components in a nitrous system (technical)
What are the individual components in a nitrous system?
Dry Direct Port System:
<U></U>
Nitrous Bottle (most popular is 10lb bottle)
Nitrous Solenoid
Hard Lines or Stainless Lines
Distribution Block (nitrous only) (4 port block for 4 cyclinders?)
Nitrous Jets
Noozles
Wet Direct Port System:
<U></U>
Nitrous Solenoid
Fuel Solenoid
Distribution Blocks (nitrous also fuel) (4 port block for 4 cyclinders?)
Nitrous Jets
Noozles
Does anyone have a diagram of how a nitrous system is properly run?
My personal plan is for:
K20z1 Motor
TWM 52mm ITBS
Nitrous Dry Direct Port
Going to use Kpro to control fuel/timing for nitrous. Also gonna try to setup a toggle switch for bottle opener/bottle heater.
Old Jun 23, 2006 | 02:59 PM
vtekthis's Avatar
Default Re: Components in a nitrous system (Jordo@KAP)
do they make a dry direct port? seems to be the most ineffiecient system tell me if im wrong.
And the dry sytem needs the valve that send it to the FPR
Plus you way better off with a full direct port with ITB's IMO
Old Jun 23, 2006 | 03:33 PM
done's Avatar
Default Re: Components in a nitrous system (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote"> do they make a dry direct port? seems to be the most ineffiecient system tell me if im wrong.
Plus you way better off with a full direct port with ITB's IMO </TD></TR></TABLE>
Care to explain?
I was going to just use kpro to add fuel/cut timing same time the nitrous was going to be strayed.
Old Jun 23, 2006 | 03:39 PM
Blaze45's Avatar
Brrraaaap!
phasechangeracing or was it 1700anddropping? Maybe the same dude, but search theres a big nitro thread that hes has quite a bit of input in and he definetly knows what hes doing.
Good luck
Blaze
Old Jun 23, 2006 | 09:59 PM
Phase Change Racing's Avatar
Default Re: Components in a nitrous system (Blaze45)
The dry direct port systems that I build are quite a little bit different from the "dry" systems you usually see. My systems are designed for the fuel enrichment to be introduced through increased pulse-width in the injectors controlled through the ecu. The usual dry systems run nitrous pressure to the vacuum side of the fuel pressure regulator to artificially bump up the fuel pressure.
Old Jun 24, 2006 | 07:27 AM
done's Avatar
Default Re: Components in a nitrous system (Phase Change Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase Change Racing &raquo;</TD></TR><TR><TD CLASS="quote">The dry direct port systems that I build are quite a little bit different from the "dry" systems you usually see. My systems are designed for the fuel enrichment to be introduced through increased pulse-width in the injectors controlled through the ecu. The usual dry systems run nitrous pressure to the vacuum side of the fuel pressure regulator to artificially bump up the fuel pressure.</TD></TR></TABLE>
yeah, thats what i plan to do.
Old Jun 25, 2006 | 08:30 PM
That design has been around for a little over 10 years now. Its a very efficient way to go as long as you have the ability to tune it properly. I've run into a number of people that try to do it this way but just don't fully understand what they need to do to make it work right.
ImportCarPartsPlus
Dec 25, 2008 01:02 PM
amy
Oct 5, 2007 11:10 AM
amy
Northeast (Sales)
24
Feb 26, 2007 06:01 PM
SiMateoAko
Apr 30, 2006 11:04 AM
