Compare Gt35s to Sc61s
Old Jul 11, 2004 | 05:07 PM
FOrSfEd's Avatar
Default Compare Gt35s to Sc61s
I've done some research but still can't really come up with any difference besides the wheels. Can anyone else give me anymore insight. Both with same trims and all. What I'm looking for is a turbo that can make some good power and lower boost leves. I would love to make over 400 runnning under 15psi.
Old Jul 11, 2004 | 05:18 PM
M.A.R.C.'s Avatar
Default Re: Compare Gt35s to Sc61s (FOrSfEd)
as far as i know (i spoke to rod about it this past week). the only main difference is the GT turbine wheels. interms of real world comparisons... he told me that inlinepro switched to one (i think from an SC61) and spoolup was pretty much the same but they picked up 50hp.
Old Jul 11, 2004 | 05:22 PM
FOrSfEd's Avatar
Default Re: Compare Gt35s to Sc61s (CivicRyda2k)
Wow thats not bad for and extra 50hp. I've found that there is only about $100.00 difference between the two. Anymore
M.A.R.C.'s Avatar
yah. i was considering upgrading hehe.
Old Jul 11, 2004 | 05:25 PM
FOrSfEd's Avatar
U wouldn't happen to know how much boost they were running do u
Old Jul 11, 2004 | 05:33 PM
M.A.R.C.'s Avatar
nah. if you want just call up precision and speak to rod. he's a cool guy, very easy to talk to and is always glad to help whenever he's not busy
to rod
Old Jul 11, 2004 | 05:40 PM
spoonhatchblack's Avatar
Just in case you guys might be looking for a GT35E. I have on for sale. Here's the link. https://honda-tech.com/zerothread?id=920822
FOrSfEd's Avatar
Yeah I would def agree with that, I've talked to him a couple times by email.
Old Jul 11, 2004 | 05:43 PM
FOrSfEd's Avatar
thats a damn good deal.
Old Jul 11, 2004 | 06:28 PM
FOrSfEd's Avatar
ttt
Old Jul 11, 2004 | 07:04 PM
Trak_Day's Avatar
New User
GT35S unless you want to bone up and go for the GT35R! If you are looking for more hp at lower boost than the GT series are gonna get you just that.
Old Jul 11, 2004 | 07:10 PM
FOrSfEd's Avatar
Default Re: (DroppedGSR)
thanks homie
Old Jul 11, 2004 | 07:22 PM
b18cls1's Avatar
Default Re: (FOrSfEd)
i vote the gt35s ...
Old Jul 11, 2004 | 07:25 PM
JDogg's Avatar
Default Re: (b18cls1)
i think for max power the sc61 will own... the t350 or t4 turbine housing is where its at
Old Jul 11, 2004 | 07:36 PM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know (i spoke to rod about it this past week). the only main difference is the GT turbine wheels. interms of real world comparisons... he told me that inlinepro switched to one (i think from an SC61) and spoolup was pretty much the same but they picked up 50hp. </TD></TR></TABLE>
They picked up 15hp, not 50hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">i think for max power the sc61 will own... the t350 or t4 turbine housing is where its at</TD></TR></TABLE>
How do you figure? the GT35 84 trim turbine wheel flows more volume and is more efficient then the T350 turbine wheel.
Old Jul 11, 2004 | 07:38 PM
M.A.R.C.'s Avatar
Default Re: Compare Gt35s to Sc61s (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the correction ... i probably just heard him wrong lol
Old Jul 11, 2004 | 07:52 PM
JDogg's Avatar
How do you figure? the GT35 84 trim turbine wheel flows more volume and is more efficient then the T350 turbine wheel.</TD></TR></TABLE>
have you ever put a gt35r and a t350 sc61 side by side...... the t350 turbine housing is way bigger than the gt35r turbine... all a more efficent turbine wheel means is less lag
Old Jul 11, 2004 | 08:21 PM
M.A.R.C.'s Avatar
Default Re: Compare Gt35s to Sc61s (JDogg)
have you ever put a gt35r and a t350 sc61 side by side...... the t350 turbine housing is way bigger than the gt35r turbine... all a more efficent turbine wheel means is less lag</TD></TR></TABLE>
i'm not smart but i wouldn't think that efficient ONLY means less lag. doesn't the turbine wheel also aid in power? when i say that i mean better designed, less restrictive wheel would create more power. it makes sense to me because hell even the sc61 is rated based on the turbine wheel... T350 SC61 ~630hp, 69 trim T04 ~650hp, T04 P-trim ~680hp.
Old Jul 11, 2004 | 08:50 PM
DIRep972's Avatar
Smarter than you
Have you seen the flow #'s for the two wheels?
Old Jul 12, 2004 | 05:47 AM
JDogg's Avatar
on precisions website all the sc61's are rated for the same 680hp
and its not the turbines alone that limit power... hell the sc50 has the same turbine specs as the sc44 and the sc60. the sc61 has a bigger housing and a bigger wheel. i have had the 2 side by side, both apart and the differences in the turbine wheels are minimal at best, the have close to the same shape, the gt35 is a touch smaller... the biggest difference is the turbine housing... anyway you cut it a t350 housing flows more than a t3 housing.... thats like saying a 1 inch hose will flow as much water as a 2 inch hose.
the compressors are the same between the 2 turbos, hell if the bolt holes were in the right spot you could swap the compressor covers.
Old Jul 12, 2004 | 05:57 AM
M.A.R.C.'s Avatar
the site must be wrong then... or maybe just an advertising ploy. rod himself told me that the differences in turbine wheels determined the power output on the SC61's. Yes they (SC50, 44, and 60) have the same turbine wheels but obviously different compressor wheels (50 trim vs 60 trim vs 60-1). The base SC61 has the same E housing as all the other turbos with the GT35R compressor wheel. T350 refers to the wheel as far as I know...
T31 69 trim = stage 2 wheel
T31 76 trim = stage 3 wheel
T350 76 trim = stage 5 wheel
so a T350 housing vs a T31 housing (i'm assuming that's what you meant by T3 housing)... the T350 would be a little bigger because of the bigger wheel.
SC61 on left, SC60 on right... T350 vs T31, both are .63 a/r T3 housings
Old Jul 12, 2004 | 06:08 AM
FOrSfEd's Avatar
I'm just wondering, if the sc61 is so much better why does the gt35 make better power at lower boost. Yeah if you were to peak out the turbos the s61 would win but I'm not looking to peak it out I just want to make good power at lower rpms and lower boost levels and it seems that the gt35 would be the better one for this
Old Jul 12, 2004 | 06:13 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">I'm just wondering, if the sc61 is so much better why does the gt35 make better power at lower boost. Yeah if you were to peak out the turbos the s61 would win but I'm not looking to peak it out I just want to make good power at lower rpms and lower boost levels and it seems that the gt35 would be the better one for this</TD></TR></TABLE>
my guess is that turbine wheel. just because it's smaller doesn't mean it's not as good. it's probably more efficient than a T350 wheel... who knows. and efficiency can be better than all out power or size right?
Old Jul 12, 2004 | 06:23 AM
JDogg's Avatar
we arent talking about low boost, we are talking max power. of course a smaller turbo (when compared to one thats too big) will make better power on low boost. that and the dual ball berings dont hurt either.
for max power, my money is on the sc61, for a normal car.. the gt35r would probably be better just because it will spool alot faster and both these turbos should be good for low 10sec power.
Old Jul 12, 2004 | 06:32 AM
FOrSfEd's Avatar
this is some really good info for both.
