Cometic or ebay head gasket?
Im building engine to "customer" and he has 2 headgaskets. Ebay full set and cometic. If car would be my own id take OEM but this is now options. Its b16 with eagle crank, rods and SPR pistons or something. I have read so much problems with cometic so should i go with ebay gasket? Deck and head is going to milled so they are straight.
If options are these what is YOUR choise? If cometic is there any needs for that like copper spray?
Golden eagle head gasket works awesome too. They also have diff bore sizes, but in your case i would take the cometic over the ebay, But oem ftw
last time i knew it was cometic
http://www.cometic.com/sportcompact.aspx
yes, and if your doing 81.50 bore, just do oem gasket. thats what im doing. and thats what everyone else mostly does and it works just fine. .50 mm is only .019".
I told him to sell ebay and cometic and ordered OEM. Get it tomorrow or wednesday when the block is ready. Its ~87 in usd here. How much is it in US ? I have used in my d16 dohc motor d16z6 OEM gasket and its 120 in USD here...
Yes i have my d16 engine with 75.5mm bore, and have used 75mm and 76mm gaskets. Works fine. I dont know what kind of engine u got but if your pistons is coming out of block, i hope u have space there so it doest hit head lol
you forgot to mention what brand gasket is being sold on ebay.
a "ebay" head gasket makes no sense......ebay does not manufacture gaskets. the seller is selling a product on ebay. that product is made by someone.
qft, last time i measured and OEM gasket it was actually 81.5mm, Honda does this to leave room for rebuilds etc and that way they don't have to make another HG for oversize etc... However OEM, Cometic, GE, all are good, i have used all with great success on cars from 250-630whp.
Either way when building motors .019" can more than make or break a motor... Ask around... :p
Also I sometimes forget to look which forum I am at and see it is the FI and not the N/A so I would hope you would not have to worry about some of the piston coming above the deck...
As blinx said above, he recalls that when he measured an oem gasket, it was 81.50. I even tested my new 81.50 je slugs and they fit through an oem gasket.
j me4door
19
Feb 15, 2009 02:45 PM
jonnythan
11
Sep 24, 2008 06:12 PM
compwc18
Jun 17, 2005 06:29 PM
