Choose a Turbo for X Factor
Old Dec 17, 2002 | 12:06 AM
VaporTrail's Avatar
New User
Default Choose a Turbo for X Factor
You guys may not have seen much of me lately, because I've been sick more in the last month than my entire life. I'm feeling a little better lately, and though I'm majorly stacked behind in work, I figured I'd post up something here to see what kinda responses I get. My car's in the body shop getting some minor work done, the motor is almost built completely. Originally, I was to use a GT3040 52 trim .82 a/r turbo, but they are on back order and I'm not in a position to really wait anymore. So, even though I have a turbo in mind for replacement, I wanna hear your suggestions.
The motor: B18c 84.5mm 9:1
Portflow'd head, spec'd to 9k rpm, JG Edlebrock intake
Lots of fuel and proper fuel management via Hondata.
XS Engineering Silvia core i/c, Inline Pro T3 flanged manifold. Maximum boost pressure set to 22psi, give or take. I wish to keep a/c, as this is a true street car.
The goals: 500+whp on race fuel. Now, pick a turbo and debate back and forth. I wanna see if you guys arrive at the same answer I have thus far.
Old Dec 17, 2002 | 02:13 AM
paulzy's Avatar
Default Re: Choose a Turbo for X Factor (VaporTrail)
get a t3/60-1 with an .82 a/r housing....send it over to me and get a turbonetics stage 5 wheel put in for cheap
Old Dec 17, 2002 | 03:17 AM
The sweed's Avatar
Default Re: Choose a Turbo for X Factor (paul_vang)
I´m in the same position here in sweden.
The shops here recomended me a schwitzer s300g and a t61 bb and the ultimate choise they recomended were a garret gt bb 35 with a t04s compressor.
Old Dec 17, 2002 | 03:19 AM
simple4012's Avatar
New User
Default Re: Choose a Turbo for X Factor (The sweed)
60-1 with .82...i agree
Old Dec 17, 2002 | 04:19 AM
internet ay's Avatar
Default Re: Choose a Turbo for X Factor (simple4012)
yes, the .82 a/r t3/60-1 sounds good. and i think cheap[turbo.com has them in stock for a good price too
Old Dec 17, 2002 | 04:33 AM
racecarpete's Avatar
Default Re: Choose a Turbo for X Factor (internet ay)
can you fit a t3/60-1 with A/C? That sound really hard.
Old Dec 17, 2002 | 04:43 AM
ekb18c's Avatar
Well if your goign to run the inline pro T3 manifold, then it only leaves you an option of running the t3/60-1 or a t3/t4.
Now the specs on that t3/6-1, well why not .82 a/r, BB, stage 5 wheel.
Old Dec 17, 2002 | 05:59 AM
tony1's Avatar
Default Re: Choose a Turbo for X Factor (ekb18c)
I'm building almost the same setup and i'm using a t3 60-1 bb with stage 5 wheel and .63 ar. Along with geoff's purty little manifold...
Old Dec 17, 2002 | 06:04 AM
boosted hybrid's Avatar
Default Re: Choose a Turbo for X Factor (tony1)
I would have to agree that the 60-1 t3/ .82a/r choice.
Old Dec 17, 2002 | 09:04 AM
SiRkid's Avatar
Default Re: Choose a Turbo for X Factor (boosted hybrid)
awe man...
that sucks.. wait for the turbo...
but i would go for a 60-1
Old Dec 17, 2002 | 02:07 PM
DLB1994's Avatar
Default Re: Choose a Turbo for X Factor (SiRkid)
VaporTrail : When are you trying to have your car ready
Old Dec 18, 2002 | 01:40 AM
VaporTrail's Avatar
New User
Default Re: Choose a Turbo for X Factor (DLB1994)
Man I haven't heard this question in a few hours LOL
Car is in the body shop getting the under hood painted and rear bumper resprayed.
Engine is mostly assembled, just gotta pop the head on the block and small ****.
Awaiting custom built clutch from RPS (carbon/carbon)
After that, just got to press on the new wheel bearings, hubs and extended studs, build all the piping. Remainder of the **** is fabrication of the fuel system. Pretty much done with the buying process, we'll take a week off from the shop and put it together ETA - late January.
Old Dec 18, 2002 | 01:42 AM
VaporTrail's Avatar
New User
Thats basically what I had in mind, but you're the only one who's said to use the .63 a/r housing. Any insight as to your choice?
Old Dec 18, 2002 | 03:02 AM
boostaholic's Avatar
i'd say go with the .82 turbine housing if you're looking for 500+whp. Innovative offers a Ball Bearing t3/60-1 .82 hot side, .70 compressor side, and Stage 5 wheel. Wish i could have afforded the BB
Old Dec 18, 2002 | 04:02 AM
C-Murdock's Avatar
Default Re: Choose a Turbo for X Factor (boostaholic)
T3/T04E BB, Stage III Wheel, 60 Trim, .60a/r compressor, .82a/r turbine....ive seen this turbo make 500-550whp, same one I have on my fully built H22...
Old Dec 18, 2002 | 05:29 AM
tony1's Avatar
I'm going with the .63 for a more usable powerband. This is for a street car primarily. I am going with the stage 5 wheel though. I've seen this same setup make 535whp with very little lag. Between the big bore motor, equal length manifold, ball bearing center, small ar, and big exhaust, i'm hoping for a very broad powerband. I'll let you know how it turns out. I would rather have a few less hp with a better powerband. If it ends up being too small then it's just a matter of changing the turbine housing.
Old Dec 18, 2002 | 05:39 AM
ArizonaTurbo's Avatar
T3/T04E
Ball Bearing
.82 A/R
Stage V
.60 A/R
60 Trim
This turbo can easliy support 500-525 whp! It will be a little less than the GT30 also.
Old Dec 18, 2002 | 09:13 AM
VaporTrail's Avatar
New User
Default Re: Choose a Turbo for X Factor (TurbochargedSER)
Seems like everyone has suggested ball bearing. Now, final question, anyone have any recommendations as to where to get it? I have 1175 to spend, but of course I don't want to spend anymore than I have to. Thanks
Old Dec 18, 2002 | 09:28 AM
What did you have in mind?
Old Dec 18, 2002 | 09:33 AM
DLB1994's Avatar
Old Dec 18, 2002 | 05:32 PM
rondigs's Avatar
Tony and I must be on the same page. Except my turbo (t3 60-1 stage 5 .63) lacks the BB. Wish I could have afforded that option. Hopefully the full-race mani will help out a little.
Old Dec 18, 2002 | 05:42 PM
VaporTrail's Avatar
New User
I haven't had much luck with turbonetics turbos, all the bb turbos I've dealt with seem to be far more durable. I was leaning towards Innovative Turbo systems or perhaps Precision Engine and Turbo. Thoughts?
Old Dec 18, 2002 | 05:52 PM
CRVRX's Avatar
John, You want big power ? , You need a big turbo = T3/T9 Z,,,,HA , John Glad you almost have your motor ready. I'll call you about Dynoing another car next week .
Later, John.
Old Dec 18, 2002 | 05:59 PM
VaporTrail's Avatar
New User
Default Re: Choose a Turbo for X Factor (CRVRX)
Later, John.
John I'll be out of town from this Saturday til Jan 2nd, but feel free to call me anyway. BTW, the other option is a T6,000,000
Old Dec 19, 2002 | 06:32 AM
I personally have no experiences with ITS or Precision turos, but I have heard nothing but good about them both. I have never had a problem with any Turbonetics turbos other than your normal rebuilt every 6-8 months. Like I said, the GT30 or GT35 may be the right turbo for you.
[Modified by TurbochargedSER, 8:32 AM 12/19/2002]
