cheapest tune out there?
wats up everyone i got a 92 integra wiht a stock motor ..255 fuel pump and my fuel pressure is at 45 rite now with stock injectors .with a turbo kit.. im running 4 psi right now wats the cheapest chip i can get? should i just go on one of them websites that set up a chip with ur setup? i have 550 cc injector (not installed) ..should i keep the stock ones or swap them out??
you can get an ebay chip cheap. but your engine will probably not last.
every car is a little different and has different needs. you shouldnt be searching for the cheapest chip, rather a reputable tuner to make your car as good as it can be.
see the list of tuners in the sticky at the top.
If you do it right the first time you will not regret it!
Devo94ac
Sep 22, 2005 09:39 PM
andyvaj
Mar 22, 2005 09:59 AM
MNTuner
Dec 9, 2002 08:40 AM
