catch can setup under $300???
Old Jan 22, 2009 | 07:37 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default catch can setup under $300???
well im at the point that im trying to figure out a catch can setup for my car, i have a built 1.9L gsr with a 35r that i plan on pushing to its limits,
are there any setups out there that are nice and will be adequate that can be had for under $300, i know the t1 is really nice but i just cant spend that kind of money right now on a catch can
Old Jan 22, 2009 | 07:52 AM
srmofo's Avatar
Default Re: catch can setup under $300???
if you dont use SS braided hose you can cut some cost and screenname (B R Fittings)sells quality stuff, its not as pretty as T1 but it gets the job done
https://honda-tech.com/forums/showth...0423&highlight=
Old Jan 22, 2009 | 07:55 AM
B R Fittings's Avatar
We have our catch can drain back kit for $290. Which includes all the AN fittings and line needed to install everything.
You will need to get the two fittings welded to the front of the valve cover,which are included in the kit. There will be two lines going from the valve cover to the side of the catch can and one line going from the bottom of the catch can to the back of the block.
https://honda-tech.com/forums/forced-induction-49/new-anodized-polished-catch-can-kits-2020423/
How much power are you looking to make? I've had customers make in the low 500's with this kit and it worked fine.
Old Jan 22, 2009 | 07:57 AM
plan on making 500+
is there anyway to get a bit bigger of a catch can with only the 2 ports going in and one drain?
Old Jan 22, 2009 | 08:01 AM
Thanks srmofo.
If you want a big breather tank we also have a 4 port breather tank as opposed to the 6 port one thats in our post($515). Its not listed on our thread.
I can give you a deal of $400 for the 4 port breather tank kit. It includes everything you need to install it from the ss hose to the AN fittings and the fittings for the back of the block.
Old Jan 22, 2009 | 08:22 AM
srmofo's Avatar
I bought the block kit, VC kit, and a turbo coolant kit from them. customer service was great...I only wish I would of bought the gallon can instead of the 2 smaller cans, I havent even installed it yet but from what I have been reading with the power I will be making, I might be having some issues I guess Ill have to wait and see
Old Jan 22, 2009 | 08:49 AM
YZFR6's Avatar
T1 catch can for sure... I know it'll be hard to get it under with all the fittings, but the fittings and hose's is the expensive part. I'd save up to get the Tony's catch can. Quality is amazing and that boy can throw a bead! Trust me
Old Jan 22, 2009 | 08:58 AM
irishflame27's Avatar
B&R or T1, they both are awesome and look pretty much identical
RedneckRicer's Avatar
i made my own T1 style catch can out of 1/8" steel plates. welded on some fittings and all my lines. i got $120 into it if that.
Old Feb 2, 2009 | 02:37 PM
steel rusts?? or did you paint it all etc
Old Feb 2, 2009 | 03:08 PM
yes i painted it. candy Purple to match my Valve Cover
Old Feb 2, 2009 | 03:27 PM
bigD's Avatar
https://honda-tech.com/forums/showthread.php?t=2020423
with the 290 kit does that get rid of the stock pcv valve and box or do you still keep it.
Old Feb 2, 2009 | 03:29 PM
bigD's Avatar
looking at the pic looks like it comes with the plug so gona guess it does get rid of it.
Old Feb 2, 2009 | 03:40 PM
Thats correct, it gets rid of the stock black box and pcv system. If you have any other questions please send me a PM.
Thanks
Brian
Old Feb 2, 2009 | 04:09 PM
cockerkid008's Avatar
B R can you post a picture of the bigger 4 port catch can setup? Im also looking at a bigger tank then the 3 port and I dont need the 6 port kit
Old Feb 2, 2009 | 09:46 PM
blinx9900's Avatar
BR fittings
Old Feb 3, 2009 | 04:43 AM
1badda's Avatar
GReat Customer Service from Brian at B&R !!!!!!!Cool GUY
Old Feb 3, 2009 | 05:02 AM
Mikey3000's Avatar
damn, how much did that end up weighing?
Old Feb 3, 2009 | 05:30 AM
maybe 2-3 lbs for the box without filters
Old Feb 3, 2009 | 08:56 AM
RedR's Avatar
i´d like to see pics as well please
Old Feb 3, 2009 | 09:02 AM
he sent them to me on AIM last night
pcguy760
Aug 13, 2008 11:21 AM
IZODIACXI
Aug 6, 2003 04:39 AM
