Cast top mount questions
http://www.ebay.com/itm/GSP-B-SERIES...10d5be&vxp=mtr
What are the power ratings on these? Junk? Restrictive? Thanks for any input. |
Re: Cast top mount questions
What are your power goals?
I've seen people make 600 on a log so it will work fine |
350-400.
I just like the top mount setups but didn't want to spend a total shit load. Just was curious on these manifolds, never really seen a review on them. |
You'll be fine
tyvm
one and made 400whp on a 57 trim garrett turbo. good manifold. be sure you get a trbo with a .60a/r compressor for best fitment. You can also get a clocking flange to make the turbo sit straight for better fitment
GT3251B is what I got from Shodan.
I removed a/c and p/s so should fit better? It's replacing my tubular setup in my 92 gsr. Was looking at this too: http://www.ebay.com/itm/CXRacing-Hon...60858277809%26 Has a matching down pipe, seems like a good deal. I have to use a 2.5" to 3" v band adapter though so gotta see if that will work or not. |
thats not a cast top mount thats a tubular chinese pos top mount
you can retain ps and ac with the cast top mount |
I realize that lol. Just was looking at others.
P/s would be nice to have again. |
you can even make the stock ac lines work wityh some creative bending, replacements are cheap though to make fit better
Ac is over rated on a non daily lol
Ac is overrated period
Ac? We don't need no stinkin ac !
Exactly
I don't even use it in the cars that have it, gives ,e a headache Hell I daily drove my s13 with no wipers, ac, heat, or blower motor. Man shit lol |
SO you keep a nice rag in the car on humid days if the weather changes while you're out for the day... yeah.. real man sh!t there, looking like a highschool kid with a towel in his hand wiping every 5 minutes.
I'm not saying there's anything wrong with no A/C, but all the rest...go ahead and DO YOU. |
I never had fogging issues unless it was a warm humid night and even then it was rare. The civic won't have ac but I have a heat only vent for it.... I'll also be keeping the wipers lol
Oh Mac, I need to talk to you about the turbo dilemma, I got confirmation that the 2871/3071 wheels are internally threaded, the 2835 wheel is as well (same thing basically) but all the info I can find says the 2835 wheel has a smaller hub height, only about 1mm or so |
my buddys old SPA/hx30 lol!
if anyone i know could break something it would be him. beat runs for hours every night and held up great. hes going big boy d series now lol. |
I have one of these sitting on my desk that a customer shipped to us to have a downpipe made. The one thing I'd be concerned about here is the wastegate port. For whatever reason it is oblong and is larger than the OD of the wg fire ring. This could be a 1 manifold isolated, problem from this one particular ebay seller (I dont know which one it was)...but if you look at the photos of the wg port on any given auction, it isnt round.
Reference pic taken for our customer of our V2 next to the one that was delivered o us. https://sphotos-b.xx.fbcdn.net/hphot...01462314_n.jpg |
^^That would turn me off to buying one. Cast logs aren't very expensive...maybe toss a few more bucks into the mix and get something better. You can find reasonbly priced InlinePro SS manifolds from time to time in the Marketplace for ~$300.
If you're set on buying a cast manifold, its hard to pass this one by: http://www.go-autoworks-store.com/gocairbsedot.html . Its very inexpensive, looks to be made well and is more than enough for your goals. It may not be a topmount, but does that really make any difference? **Just realized this last manifold requires a 5-bolt exhaust housing...I dont know which housing came with your GT32521b, but I would assume its a 4 bolt. Something to be mindful of when looking at various manifolds |
Originally Posted by wantboost
(Post 48330062)
Originally Posted by Schister66
(Post 48331748)
The one on the right from Greg also looks not only oblong, but also looks like there's exhaust turbulence right at the fore-front. I'd avoid it at all costs. |
(Post 48331748)
If you're set on buying a cast manifold, its hard to pass this one by: http://www.go-autoworks-store.com/gocairbsedot.html . Its very inexpensive, looks to be made well and is more than enough for your goals. It may not be a topmount, but does that really make any difference? **Just realized this last manifold requires a 5-bolt exhaust housing...I dont know which housing came with your GT32521b, but I would assume its a 4 bolt. Something to be mindful of when looking at various manifolds If setting up to configure for for an A/C setup, then a 5 bolt/B cover turbo is needed for appropriate clearance. If its non a/c with a passenger side exit downpipe then you can use whatever T3 turbine outlet you want. |
Probably too big for a 38mm fire ring but I bet it would fit that goofy wastegate you had to run on that one inline pro mani
He spa is defiantly better quality than these knock offs. Wastegate placement is perfect but that oblong opening isn't very good on that knock off unit. You don't need a clocking flange for a turbo to fit just fits better. You can run an E cover .60 and still retain ac and ps. It will fit an s cover without a clocking flange but not with one
