Car won't start. HELP!
Old Aug 31, 2003 | 09:37 AM
E Swift's Avatar
Default Car won't start. HELP!
Last night, my car ran fine. Today, I didn't drive it at all. I changed the oil today, and tried starting it, but it doesn't start. It cranks, but, won't start. It's also throwing a check engine light. I thought that the car won't throw a check engine light when you're running the EMS standalone?
Old Aug 31, 2003 | 12:43 PM
E Swift's Avatar
Default Re: Car won't start. HELP! (E Swift)
Checked the spark plugs, tips are white. Is there any trouble shooting that can be done to find the problem?
Old Aug 31, 2003 | 12:57 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E Swift &raquo;</TD></TR><TR><TD CLASS="quote">It cranks, but, won't start. It's also throwing a check engine light. </TD></TR></TABLE>
Does it have spark? What code does it have stored?
Old Aug 31, 2003 | 01:19 PM
E Swift's Avatar
Default Re: Car won't start. HELP! (Chiovnidca)
I haven't checked to see if it has spark, but I did pull the cap and rotor off, and when I removed the rotor, the screw that holds it on, just popped out, as if it were not even holding the rotor in. Could have possibly prevent it from starting?
Old Aug 31, 2003 | 01:41 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E Swift &raquo;</TD></TR><TR><TD CLASS="quote">I haven't checked to see if it has spark, but I did pull the cap and rotor off, and when I removed the rotor, the screw that holds it on, just popped out, as if it were not even holding the rotor in. Could have possibly prevent it from starting?</TD></TR></TABLE>
Yes, if it lets the rotor spin on the shaft.
Old Aug 31, 2003 | 02:39 PM
E Swift's Avatar
I just bought a new rotor, and still doesn't start. The NGK plugs are still fairly new, but my plug wires could definetly use a change though.
Old Aug 31, 2003 | 06:21 PM
E Swift's Avatar
^ bump ^
Old Aug 31, 2003 | 07:02 PM
Chiovnidca's Avatar
Default Re: (E Swift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E Swift &raquo;</TD></TR><TR><TD CLASS="quote">^ bump ^</TD></TR></TABLE>
Old Sep 2, 2003 | 05:02 PM
E Swift's Avatar
Default Re: (Chiovnidca)
Just had a shop check my coil, which they say is still good. I just checked for spark, and there is none. Would this lead towards the ignitor being the problem?
Old Sep 3, 2003 | 02:56 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E Swift &raquo;</TD></TR><TR><TD CLASS="quote">Just had a shop check my coil, which they say is still good. I just checked for spark, and there is none. Would this lead towards the ignitor being the problem?</TD></TR></TABLE>
Old Sep 3, 2003 | 03:30 PM
E Swift's Avatar
I bought a new ignitor, and it still doesn't start. And there still is no spark. How do I know what the code is? The check engine light just comes on and stays on while I'm cranking the motor.
Old Sep 3, 2003 | 03:38 PM
ekb18c's Avatar
what standalone are you using?
Old Sep 3, 2003 | 03:42 PM
E Swift's Avatar
Default Re: Car won't start. HELP! (ekb18c)
AEM EMS
Old Sep 3, 2003 | 05:01 PM
dubracr18t's Avatar
How to get the codes http://www.c-speedracing.com/faq/06.php
How to read the codes http://www.c-speedracing.com/faq/05.php
Old Sep 3, 2003 | 05:29 PM
E Swift's Avatar
Default Re: Car won't start. HELP! (dubracr18t)
Will those codes work even though I'm using the AEM EMS standalone ECU?
Old Sep 3, 2003 | 05:46 PM
E Swift's Avatar
Okay, I crossed the blue clip with a paperclip just as C-Speedracing said, and the light just comes on and stays on. It doesn't flash at all.
EKcpe00
Nov 14, 2010 02:27 PM
tambara
16
Apr 20, 2008 01:01 PM
93h22a1vtec
Jun 3, 2006 07:47 AM
sohc90rex
16
Dec 21, 2005 09:20 PM
CWITR
May 3, 2005 04:38 PM
