car warms up then cools down.. normal??
Old Feb 21, 2005 | 04:44 PM
turbo_ef9's Avatar
Default car warms up then cools down.. normal??
well heres the deal.. my car has a huge fmic blocking my radiator.. the last time that happenend my car overheated alot... well with this car, it goes to normal temps on the gauge.. after like 10 mins of constant driving the cars temp gauge shows cold.. im talking cold like before u start it up cold.. i pop the hood and the motor is normal temp hot.. also the heat fluctuates up and down also when this happens... it'll be hot then be blowing out cold air.. is it just the big fmic workin its magic or is there something wrong?
Old Feb 21, 2005 | 04:59 PM
NJIN BUILDR's Avatar
Default Re: car warms up then cools down.. normal?? (eli_vang)
You have air trapped in your cooling system.You need to bleed the system asap.
Glenn
Old Feb 21, 2005 | 05:17 PM
platinum00's Avatar
Default Re: car warms up then cools down.. normal?? (NJIN BUILDR)
run the car with the cap off till the engine warms up. and see if you have bubbles.
please dont open the cap with the car already warmed up.
platinum.
Old Feb 21, 2005 | 06:02 PM
underpressure02's Avatar
bleed the system. I had the same thing happen to me right before I cracked a sleeve.
Old Feb 21, 2005 | 07:18 PM
m R g S r's Avatar
Default Re: car warms up then cools down.. normal?? (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">bleed the system. I had the same thing happen to me right before I cracked a sleeve. </TD></TR></TABLE>
I thopught air raised the temp. . .
I'm saying sticking thermostat. . . . . .
the cool coolant just goes right back into the block, instead of being stopped by the thermo
Old Feb 22, 2005 | 05:28 PM
turbo_ef9's Avatar
Default Re: car warms up then cools down.. normal?? (m R g S r)
how do u bleed the system? just run the car with the cap off till it warms up? or leave the cap on and use the lil bleeder valves on the motor? with the bleeders u just open them up and turn the car on untill fluid comes out? then pour in to fill right?
Old Feb 22, 2005 | 07:08 PM
SOHC_MShue's Avatar
you should have the bleeder valve if you have a z6 so i would use that.
Old Feb 23, 2005 | 12:45 PM
turbo_ef9's Avatar
also forgot to add this started happening after i replaced my half sized broken radiator for my full length.. also.. i ran the car with the cap off and it bubbled just a tad bit.. it raised to the top like 2 minutes later.. wasn't warmed up or anything yet... did i do that right? im coming to a conclusion saying that my thermo is stuck.. i'll get that fixed first.. any other suggestions?
Old Feb 23, 2005 | 01:24 PM
RobbieG35's Avatar
12 Years Strong
My B16 CRX was doing the same thing, I replaced the thermostat (which had never been replaced before) and it corrected the problem. This also required that I bleed the coolant, so I would try bleeding the coolant system before I did the thermostat.
stdefhatch
Dec 19, 2009 08:44 AM
Toe_Knee
Apr 11, 2009 11:55 AM
eurodeseo
Jul 4, 2006 06:55 PM
Hondaciv95VX
20
Dec 5, 2005 01:41 PM
revvin9k
Dec 29, 2004 08:12 PM
