Car stalls at lights
Old Oct 12, 2006 | 10:20 AM
1slowdc2's Avatar
Default Car stalls at lights
Hello all, i hope you guys can help me with my problem. Sometimes when i start to stop at a light or sign, i push the clutch in and the RPMs will fall to 500rpm and then up to 1000rpm, sometimes it will fall to 500 then die. It will restart no problem and idles fine at start.
This is on a 97 GSR 2.0ltr, sleeved, pistons, rods, drag kit, hondata, 440's, walbro 255, springs and retainers. It has also been tuned.
Old Oct 12, 2006 | 10:37 AM
91dxcrx's Avatar
Default Re: Car stalls at lights (1slowdc2)
my friends fully built sohc turbo setup did the same thing...we could never figure it out and it was annoying as hell..hopefully somebody can help out
Old Oct 12, 2006 | 10:56 AM
turbotime's Avatar
does it die it if you just let it idle with no brake [pedal]?
Old Oct 12, 2006 | 11:06 AM
1slowdc2's Avatar
Default Re: (turbotime)
Not sure, it happend in reverse with no brake.
Old Oct 12, 2006 | 11:09 AM
Bfreeman's Avatar
IAC?? maybe...
Old Oct 12, 2006 | 11:12 AM
RacerXI's Avatar
Default Re: Car stalls at lights (Bfreeman)
What does your car normally idle at? Is the warm idle speed correct? If not the car will idle hunt and that will cause one to die randomly especially going into straight vacuum.
adseguy's Avatar
This sometimes happens before I tune a car. It might be too lean at idle and the car can't catch itself. If you can adjust it your self, bump up the idle and richen it up.
Old Oct 12, 2006 | 11:57 AM
1slowdc2's Avatar
Default Re: Car stalls at lights (adseguy)
The car normally idles at 1000rpm. At cold start it will be at 1500rpm, after it is warm it will be at 1000rpm. And i can't tune the Hondata my self. Can i up the fuel with a fuel presure regulator, and if i do will that change my A/F ratio through out the whole RPM band?
function_si
Oct 1, 2008 05:52 PM
93c1sol
Apr 23, 2006 08:31 PM
byronl
Jun 15, 2005 06:37 PM
LoSt is BlaCk
Mar 26, 2004 05:07 AM
