car smoking white....?
Old Mar 30, 2009 | 05:41 PM
HondaKid936's Avatar
Default car smoking white....?
okay so i put my head back on after a cam seal leak... and i turned it on and it started smoking white my uncle pulled the plug from cylinder 3 and said its white your getting air.....
he checked my intake manifold bolts and a couple were stripped and maybe a few holding i have a HONDATA intake mani so it was kinda hard to tighten.....
i had been boosting a little before this and id run maybe a couple of times and then it would die when i put it in neutral,
"what could cause this smoke and it dieying out after couple of runs? the intake manifold?"
Old Mar 30, 2009 | 06:50 PM
Default Re: car smoking white....?
bump
Old Mar 30, 2009 | 07:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
because your intake manifold is stripped in a few places coolant is getting into your head you need to fix the threads and tighten them down put some hondabond around the coolant hole on the hondta gasket between the gasket and man.!
Old Mar 30, 2009 | 07:26 PM
apreciate it bro!!!!!
Old Mar 30, 2009 | 07:56 PM
iwanttokillgod's Avatar
if you had a cam seal leak why would you take the whole head off
Old Apr 5, 2009 | 01:18 PM
i took apart the head not completely took it off
Old Apr 5, 2009 | 02:21 PM
bada9's Avatar
oil or coolant getting in your cylanders
Old Apr 5, 2009 | 02:47 PM
Romo Pyro's Avatar
Sounds like water in the cylinders (bad gasket?), which can dilute the air/fuel mixture (hence your tendency to die). check your coolant levels constantly. if your constantly running low on coolant, buy new gaskets.
MGX
Sep 4, 2011 10:01 AM
vonttcha
Nov 11, 2009 06:54 AM
tbuck23
Apr 10, 2007 08:53 PM
matix
Sep 13, 2006 06:36 PM
littleblue
Jan 25, 2006 07:13 AM
